We have an issue that UART_DOWNLOAD_DIS is not being disabled when we enabled Secure Boot v2 and Flash Encryption.
We have tried to burn this fuse after enabling Secure Boot and Flash Encryption, however the fuse is set as "read only" and we are not able to burn it anymore. We are using ESP-IDF 4.1 (573f5de99ad615364d9acf0f22fc9ee34bacbb09)
Here is summary from espefuse.py:
espefuse.py v3.0
EFUSE_NAME (Block) Description = [Meaningful Value] [Readable/Writeable] (Hex Value)
Calibration fuses:
BLK3_PART_RESERVE (BLOCK0): BLOCK3 partially served for ADC calibration data = False R/W (0b0)
ADC_VREF (BLOCK0): Voltage reference calibration = 1100 R/- (0b10000)
Config fuses:
XPD_SDIO_FORCE (BLOCK0): Ignore MTDI pin (GPIO12) for VDD_SDIO on reset = False R/W (0b0)
XPD_SDIO_REG (BLOCK0): If XPD_SDIO_FORCE, enable VDD_SDIO reg on reset = False R/W (0b0)
XPD_SDIO_TIEH (BLOCK0): If XPD_SDIO_FORCE & XPD_SDIO_REG = 1.8V R/W (0b0)
CLK8M_FREQ (BLOCK0): 8MHz clock freq override = 49 R/W (0x31)
SPI_PAD_CONFIG_CLK (BLOCK0): Override SD_CLK pad (GPIO6/SPICLK) = 0 R/W (0b00000)
SPI_PAD_CONFIG_Q (BLOCK0): Override SD_DATA_0 pad (GPIO7/SPIQ) = 0 R/W (0b00000)
SPI_PAD_CONFIG_D (BLOCK0): Override SD_DATA_1 pad (GPIO8/SPID) = 0 R/W (0b00000)
SPI_PAD_CONFIG_HD (BLOCK0): Override SD_DATA_2 pad (GPIO9/SPIHD) = 0 R/W (0b00000)
SPI_PAD_CONFIG_CS0 (BLOCK0): Override SD_CMD pad (GPIO11/SPICS0) = 0 R/W (0b00000)
DISABLE_SDIO_HOST (BLOCK0): Disable SDIO host = False R/W (0b0)
Efuse fuses:
WR_DIS (BLOCK0): Efuse write disable mask = 389 R/W (0x0185)
RD_DIS (BLOCK0): Efuse read disable mask = 1 R/- (0x1)
CODING_SCHEME (BLOCK0): Efuse variable block length scheme
= NONE (BLK1-3 len=256 bits) R/W (0b00)
KEY_STATUS (BLOCK0): Usage of efuse block 3 (reserved) = False R/W (0b0)
Identity fuses:
MAC (BLOCK0): Factory MAC Address
= b8:f0:09:92:13:28 (CRC 0xac OK) R/W
MAC_CRC (BLOCK0): CRC8 for factory MAC address = 172 R/W (0xac)
CHIP_VER_REV1 (BLOCK0): Silicon Revision 1 = True R/W (0b1)
CHIP_VER_REV2 (BLOCK0): Silicon Revision 2 = True R/W (0b1)
CHIP_VERSION (BLOCK0): Reserved for future chip versions = 2 R/W (0b10)
CHIP_PACKAGE (BLOCK0): Chip package identifier = 1 R/W (0b001)
MAC_VERSION (BLOCK3): Version of the MAC field = 0 R/W (0x00)
Security fuses:
FLASH_CRYPT_CNT (BLOCK0): Flash encryption mode counter = 127 R/- (0b1111111)
UART_DOWNLOAD_DIS (BLOCK0): Disable UART download mode (ESP32 rev3 only) = False R/- (0b0)
FLASH_CRYPT_CONFIG (BLOCK0): Flash encryption config (key tweak bits) = 15 R/W (0xf)
CONSOLE_DEBUG_DISABLE (BLOCK0): Disable ROM BASIC interpreter fallback = True R/W (0b1)
ABS_DONE_0 (BLOCK0): Secure boot V1 is enabled for bootloader image = False R/W (0b0)
ABS_DONE_1 (BLOCK0): Secure boot V2 is enabled for bootloader image = True R/W (0b1)
JTAG_DISABLE (BLOCK0): Disable JTAG = True R/W (0b1)
DISABLE_DL_ENCRYPT (BLOCK0): Disable flash encryption in UART bootloader = True R/W (0b1)
DISABLE_DL_DECRYPT (BLOCK0): Disable flash decryption in UART bootloader = True R/W (0b1)
DISABLE_DL_CACHE (BLOCK0): Disable flash cache in UART bootloader = True R/W (0b1)
BLOCK1 (BLOCK1): Flash encryption key
BLOCK2 (BLOCK2): Secure boot key
= 15 76 89 7b 42 db fb f1 3b 5f 54 f9 ec cb 0d 3d 87 5f 41 84 d0 84 8f eb 37 d9 09 88 36 41 07 95 R/-
BLOCK3 (BLOCK3): Variable Block 3
= 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 00 R/W
Flash voltage (VDD_SDIO) determined by GPIO12 on reset (High for 1.8V, Low/NC for 3.3V).
/Erik
