Open drain output max voltage
iamflimflam1
Postby iamflimflam1 » Tue Dec 08, 2020 2:41 pm
Hi All,
I've set the output mode of the GPIO pin to open drain and was wondering what is the maximum voltage I can pull up to?
Chris
becorey
Re: Open drain output max voltage
Postby becorey » Tue Dec 08, 2020 10:07 pm
Probably 3.6V, that is the absolute maximum rating of any power pin on the esp32. For safety margin, you shouldn't go to 3.6V, 3.3V is safe.
If you need to control a higher voltage you need to use a mosfet or transistor.
iamflimflam1
Postby iamflimflam1 » Wed Dec 09, 2020 1:48 pm
I can't find many (any) details on the output drivers.
I thought that unless there are protection diodes that would take the voltage back to the supply rails you should be safe pulling up an open-drain output to a higher voltage as it won't be connected to anything when the output is off?
Postby Sprite » Thu Dec 10, 2020 1:46 am
...unless there are protection diodes that would take the voltage back to the supply rails...
The ESP has internal ESD protection snapback devices that essentially work like diodes taking the voltage back to the power rails.
Users browsing this forum: Amazon [Bot] and 1 guest
