ESP-NOW protocol measure receiver power strength of signal strength
stoicLemons
Postby stoicLemons » Wed Jan 15, 2020 9:27 pm
I would like to measure the RX power or signal strength while using the ESP-NOW protocol and varying the TX power in the code. Would using a spectrum analyzer achieve this?
plajjd
Re: ESP-NOW protocol measure receiver power strength of signal strength
Postby plajjd » Thu Dec 24, 2020 10:24 pm
We also use ESP-NOW protocol and read the signal strength from each received packet. To do so, you have to configure a "promiscuous mode" callback function that will be called when each packet is received. For instance:
        esp_wifi_set_promiscuous(true);
        esp_wifi_set_promiscuous_rx_cb(&promiscuous_rx_cb);
In the callback function, you can read the RSSI value from the packet header
void promiscuous_rx_cb(void *buf, wifi_promiscuous_pkt_type_t type) {
    // All espnow traffic uses action frames which are a subtype of the mgmnt frames so filter out everything else.
    if (type != WIFI_PKT_MGMT)
        return;
    static const uint8_t ACTION_SUBTYPE = 0xd0;
    static const uint8_t ESPRESSIF_OUI[] = {0x18, 0xfe, 0x34};
    const wifi_promiscuous_pkt_t *ppkt = (wifi_promiscuous_pkt_t *)buf;
    const wifi_ieee80211_packet_t *ipkt = (wifi_ieee80211_packet_t *)ppkt->payload;
    const wifi_ieee80211_mac_hdr_t *hdr = &ipkt->hdr;
    // Only continue processing if this is an action frame containing the Espressif OUI.
    if ((ACTION_SUBTYPE == (hdr->frame_ctrl & 0xFF)) &&
        (memcmp(hdr->oui, ESPRESSIF_OUI, 3) == 0)) {
         int rssi = ppkt->rx_ctrl.rssi;
Phil.
jacoduplooy
Postby jacoduplooy » Sat Jun 26, 2021 2:07 pm
See no one replied to your solution but that was very useful to me. Thanks a lot Phil
mferrarotti
Postby mferrarotti » Tue Sep 07, 2021 4:39 pm
Hello there!
I believe I got this working, but need further testing:
https://otroblogdemarcelo.wordpress.com ... l-esp-now/
Any input?
Cheers,
Marcelo from Argentina
mferrarotti
Postby mferrarotti » Tue Sep 14, 2021 1:55 pm
Hello there, I just got confirmation of this RSSI implementation working, can anyone else test this?
Thanks!
JeanPinhal
Postby JeanPinhal » Thu Nov 04, 2021 2:32 pm
How can I get MAC related to RSSI on multiple ESPNOW?
ngobduong
Postby ngobduong » Mon Apr 22, 2024 3:39 am
can anyone share a full code
Users browsing this forum: ChatGPT-User, Google [Bot], Qwantbot and 1 guest
