[Solved] Can RTC IO output state be retained in hibernation mode?
krzychb
Contact:
Postby krzychb » Thu May 25, 2017 8:42 pm
Hey everybody,
According to ESP32 Datasheet V1.3 on page 22, in hibernation mode "some RTC GPIOs are active".
I understand they can be used as "ext0" or "ext1" wakeup sources after configuring them as inputs.
What if they are configured as outputs? Can they retain output state (high or low) that has been set up before putting the chip into hibernation mode?
igrr
Re: Can RTC IO output state be retained in hibernation mode?
Postby igrr » Fri May 26, 2017 12:53 am
For RTC IOs you can use rtc_gpio_hold_en function.
For digital IOs there is a RTC_CNTL_DG_PAD_FORCE_HOLD bit which forces all pads to hold their state.
krzychb
Contact:
Postby krzychb » Fri May 26, 2017 6:23 am
Thanks @ESP_igrr!
Works great from both main program (using rtc_gpio_hold_en / dis) and from ULP (using individual registers and bits).
EDIT:
A short description how to use hold enable / disable functionality together with an ULP program is available under https://github.com/krzychb/ulp-loop
davdav
Re: [Solved] Can RTC IO output state be retained in hibernation mode?
Postby davdav » Mon May 20, 2019 1:23 pm
Thanks @ESP_igrr!
EDIT:
Hi @krzychb, I have studied and tested your example code and it is very usefull to understand deep-sleep and RTC GPIOs.
I have a question: in my case I need to put in hybernation (i.e. deep-sleep within only RTC timer, no slow/fast memory, no ULP) retaining GPIO23 (which is not RTC).
I have written a very simple test:
main(){
    printf("RESET:%d;wake:%d\n", rtc_get_reset_reason(0), esp_sleep_get_wakeup_cause());
	//wait start
	uint8_t cnt=0;
	while (cnt < 3)
		printf("startWait:%d\n", cnt);
		vTaskDelay(pdMS_TO_TICKS(1000));
		cnt++;
    //Config gpio_num_23
	gpio_config_t config = {
            .pin_bit_mask = BIT64(GPIO_NUM_23),
            .mode = GPIO_MODE_OUTPUT,
			.pull_up_en = GPIO_PULLUP_DISABLE,
			.pull_down_en = GPIO_PULLDOWN_DISABLE
    ESP_ERROR_CHECK(gpio_config(&config));
	cnt = 0;
	while (cnt < 3)
		printf("After config:%d\n", cnt);
		cnt++;
	// Wake up in 5 seconds
	esp_sleep_enable_timer_wakeup(5000000);
	printf("set LOW GPIO_NUM_23 and HOLD\n");
	gpio_set_level(GPIO_NUM_23,0);
	gpio_deep_sleep_hold_en();
	printf("going to DEEP SLEEP\n");
	esp_deep_sleep_start();
GPIO_NUM_23 is retained during deep sleep as expected but when ESP32 wake up (I checked from rtc_get_reset_reason(0) which is "DEEPSLEEP_RESET" and esp_sleep_get_wakeup_cause() which is "ESP_SLEEP_WAKEUP_TIMER")
the pin goes high (I guess for its internal pull-up) until the "gpio_config" function is called.
Is it mandatory to introduce a wake stub in order to retain the GPIO level after wake-up from deep sleep?
andrewandroid
Postby andrewandroid » Sat Dec 26, 2020 8:53 am
Hi ESP_Igrr,
That sounds perfect! Could you please provide an example of how to set that bit on, for beginners like me?
Pushing my luck, is there a way to set this in Arduino IDE for ESP32?
Cheers
Andrew
Users browsing this forum: Baidu [Spider], Bing [Bot], Semrush [Bot] and 1 guest
