Regarding ESP32-WROOM-32E certifications
axellin
Postby axellin » Wed Jul 01, 2020 5:12 am
On the web site https://www.espressif.com/en/support/do ... rtificates ,
I found ESP32-WROOM-32D has CE/NCC/MIC/IC/KCC/FCC.
But ESP32-WROOM-32E only has CE/FCC, how about the status of NCC/MIC/IC/KCC?
axellin
Re: Regarding ESP32-WROOM-32E certifications
Postby axellin » Fri Aug 28, 2020 2:27 am
I just check the website again, the ESP32-WROOM-32E has IC and MIC now.
But the NCC and KCC are still missing.
Do you have ETA to get NCC and KCC?
(It seems odd because ESP32-WROVER-E already has both NCC and KCC).
axellin
Postby axellin » Fri Nov 06, 2020 1:11 am
The reason we switch from ESP32-WROOM-32D to ESP32-WROOM-32E is because of the fault injection vulnerability issue.
But some of the certificates aere not available for ESP32-WROOM-32E.
Do you have timeline to get KCC for ESP32-WROOM-32E?
Peter
Postby Peter » Fri Nov 06, 2020 9:38 am
Hi ,
The KCC certificate of ESP32-WROOM-32E will be available on end of December.
axellin
Postby axellin » Fri Nov 06, 2020 9:47 am
Hi ,
Thanks for the update.
How about NCC which is also available for ESP32-WROOM-32D but not yet available for ESP32-WROOM-32E?
axellin
Postby axellin » Fri Jan 29, 2021 1:22 am
I found both KCC and NCC certificates on your website now. Thanks.
microprogel2
Postby microprogel2 » Sun Oct 17, 2021 8:13 pm
I have to certify a product in Korea where I use to install the module ESP32-WROOM-32E.
The Korean entity that is checking the product and they are asking if this module has tested according to KN301 489 , they like to have also the test report related to the KCC certificate number R-C-es5-ESP32WROOM32E
Some one can help me?
Thank you in advance
Valter
Postby Sprite » Mon Oct 18, 2021 1:23 am
Suggest emailing sales@espressif.com for this.
