BTW, while the PDM out worked amazingly on ESP32, the driver support for it could be better. It doesn't work with APLL out of the box. I need to modify a few driver files to make the clock calculation right with APLL.
PDM Tx Available in ESP32-S2?
Hello, I have just got an ESP32s2 dev board, and trying to port an old ESP32 project which uses I2S0 PDM tx mode (which is essentially a free 16-bit single channel delta-sigma DAC
) to play audio. I was thinking that the I2S on ESP32s2 is similar to the I2S0 on ESP32, however, I soon realized that the current I2S driver doesn't take the I2S_MODE_PDM bit in. I also couldn't find any references of PDM Tx/Rx in the TRM. I wonder if it is the driver and documentation haven't caught up, or the function has been removed in S2.
