rmt_config_t rmt_rx;
rmt_config_t rmt_rx={0};
distance = 340.29 * ITEM_DURATION(item->duration0) / ( 2000000 ); // distance in meters
#include <stdio.h>
#include <string.h>
#include "freertos/task.h"
#include "freertos/queue.h"
#include "freertos/semphr.h"
#include "esp_err.h"
#include "esp_log.h"
#include "driver/rmt.h"
#include "driver/periph_ctrl.h"
#include "soc/rmt_reg.h"
#include <sys/time.h>
#include "driver/gpio.h"
#define RMT_TX_CHANNEL 1 /* RMT channel for transmitter */
#define RMT_TX_GPIO_NUM PIN_TRIGGER /* GPIO number for transmitter signal */
#define RMT_RX_CHANNEL 0 /* RMT channel for receiver */
#define RMT_RX_GPIO_NUM PIN_ECHO /* GPIO number for receiver */
#define RMT_CLK_DIV 100 /* RMT counter clock divider */
#define RMT_TX_CARRIER_EN 0 /* Disable carrier */
#define rmt_item32_tIMEOUT_US 9500 /*!< RMT receiver timeout value(us) */
#define RMT_TICK_10_US (80000000/RMT_CLK_DIV/100000) /* RMT counter value for 10 us.(Source clock is APB clock) */
#define ITEM_DURATION(d) ((d & 0x7fff)*10/RMT_TICK_10_US)
#define PIN_TRIGGER 18
#define PIN_ECHO 19
static void HCSR04_tx_init()
rmt_config_t rmt_tx={0};
rmt_tx.channel = RMT_TX_CHANNEL;
rmt_tx.gpio_num = RMT_TX_GPIO_NUM;
rmt_tx.mem_block_num = 1;
rmt_tx.clk_div = RMT_CLK_DIV;
rmt_tx.tx_config.loop_en = false;
rmt_tx.tx_config.carrier_duty_percent = 50;
rmt_tx.tx_config.carrier_freq_hz = 3000;
rmt_tx.tx_config.carrier_level = 1;
rmt_tx.tx_config.carrier_en = RMT_TX_CARRIER_EN;
rmt_tx.tx_config.idle_level = 0;
rmt_tx.tx_config.idle_output_en = true;
rmt_tx.rmt_mode = 0;
rmt_config(&rmt_tx);
rmt_driver_install(rmt_tx.channel, 0, 0);
static void HCSR04_rx_init()
rmt_rx.channel = RMT_RX_CHANNEL;
rmt_rx.gpio_num = RMT_RX_GPIO_NUM;
rmt_rx.clk_div = RMT_CLK_DIV;
rmt_rx.mem_block_num = 1;
rmt_rx.rmt_mode = RMT_MODE_RX;
rmt_rx.rx_config.filter_en = true;
rmt_rx.rx_config.filter_ticks_thresh = 100;
rmt_rx.rx_config.idle_threshold = rmt_item32_tIMEOUT_US / 10 * (RMT_TICK_10_US);
rmt_config(&rmt_rx);
rmt_driver_install(rmt_rx.channel, 1000, 0);
void app_main()
HCSR04_tx_init();
HCSR04_rx_init();
rmt_item32_t item;
item.level0 = 1;
item.duration0 = RMT_TICK_10_US;
item.level1 = 0;
item.duration1 = RMT_TICK_10_US; // for one pulse this doesn't matter
size_t rx_size = 0;
RingbufHandle_t rb = NULL;
rmt_get_ringbuf_handle(RMT_RX_CHANNEL, &rb);
rmt_rx_start(RMT_RX_CHANNEL, 1);
//double distance = 0;
float distance = 0;
for(;;)
rmt_write_items(RMT_TX_CHANNEL, &item, 1, true);
rmt_wait_tx_done(RMT_TX_CHANNEL, portMAX_DELAY);
rmt_item32_t* item = (rmt_item32_t*)xRingbufferReceive(rb, &rx_size, 1000);
//distance = 340.29 * ITEM_DURATION(item->duration0) / (1000 * 1000 * 2); // distance in meters
printf("Distance is %f cm\n", distance * 100); // distance in centimeters
vRingbufferReturnItem(rb, (void*) item);
vTaskDelay(200 / portTICK_PERIOD_MS);
Guru Meditation Error: Core 0 panic'ed (LoadProhibited). Exception was unhandled.
Core 0 register dump:
PC : 0x400d248d PS : 0x00060530 A0 : 0x800d0b09 A1 : 0x3ffb4d10
0x400d248d: app_main at /home/thoth/git/A9thinker/GPRS_C_SDK/tank_gauge/sr04test/main/bstx03_XiuxinESP32.c:89 (discriminator 1)
A2 : 0x00000000 A3 : 0x00000001 A4 : 0x00000001 A5 : 0x00000001
A6 : 0x00060021 A7 : 0x00000000 A8 : 0x800d248b A9 : 0x3ffb4cd0
A10 : 0x00000000 A11 : 0x3ffb4d14 A12 : 0x000003e8 A13 : 0x00000001
A14 : 0x00000040 A15 : 0x3ffb699c SAR : 0x00000020 EXCCAUSE: 0x0000001c
EXCVADDR: 0x00000000 LBEG : 0x4000c46c LEND : 0x4000c477 LCOUNT : 0x00000000
ELF file SHA256: 3557e67f93dae1bed9df867b800bd1c138d6258b7677ba69e6fbc3003389d3c1
Backtrace: 0x400d248d:0x3ffb4d10 0x400d0b06:0x3ffb4d40 0x40085625:0x3ffb4d60
0x400d0b06: main_task at /home/thoth/esp/esp-idf/components/esp32/cpu_start.c:527
0x40085625: vPortTaskWrapper at /home/thoth/esp/esp-idf/components/freertos/port.c:403
Rebooting...
#include <stdio.h>
#include <string.h>
#define PIN_ECHO 19
static const char* NEC_TAG = "NEC";
void app_main()
HCSR04_tx_init();
HCSR04_rx_init();
rmt_item32_t item;
item.level0 = 1;
item.level1 = 0;
size_t rx_size = 0;
//float distance = 0;
for(;;)
if(item){
// distance = 340.29 * ITEM_DURATION(item->duration0) / ( 2000000 ); // distance in meters
ESP_LOGI(NEC_TAG, "Distance is %f cm\n", distance * 100); // distance in centimeters
} else {
ESP_LOGI(NEC_TAG, "Distance is not readable");
vTaskDelay(20 / portTICK_PERIOD_MS);
Which calculation are you talking about?The time taken to perform that calculation is less than 1/1000 the time to get the distance from the hcsr04.
Insignificant.
Insignificant.
Users browsing this forum: IvanSvarkovsky and 1 guest
