New ESP32 Board Bootloader
lannocm
Re: New ESP32 Board Bootloader
Postby lannocm » Wed Feb 10, 2021 10:09 am
u1 the voltage regulator
So, what should this look like?
Also there is no flash chip on the schematic so are you using esp32-u4wdh?
You have all the information I have. Is this, perhaps, the extra hardware that the designer mentioned?
Where should it go and how is it connected?
WiFive
Postby WiFive » Wed Feb 10, 2021 5:21 pm
Should be connected to vbat_out instead of vbat+ but might still work.
No I don't have the bill of materials you sent to the pcb manufacturer
First step is to test the 3v3 testpoint with a meter
lannocm
Postby lannocm » Wed Feb 10, 2021 8:29 pm
Attached is the BOM. I will try the voltage tomorrow, thanks
syp_cam_design.pdf
(58.5 KiB) Downloaded 416 times
WiFive
Postby WiFive » Wed Feb 10, 2021 9:56 pm
According to that your board has no flash so it won't do anything useful even if you get the USB comms working. It is a faulty design.
lannocm
Postby lannocm » Fri Feb 12, 2021 1:53 pm
That's a bit of a killer blow. I'm trying to get a response from the designer. I'll let you know what he says.
Thanks.
lannocm
Postby lannocm » Wed Feb 17, 2021 4:59 pm
I'm told that the flash is the PSRAM, so it is included. The designer has had another look and he is satisfied that it is correct. However, we still can't get a connection on a serial interface.
lannocm
Postby lannocm » Wed Feb 17, 2021 5:38 pm
I tried the 3.3v test point and it is ok.
WiFive
Postby WiFive » Wed Feb 17, 2021 6:15 pm
Flash and psram are different and not interchangeable so he is wrong
lannocm
Postby lannocm » Wed Feb 17, 2021 9:09 pm
Does this explain why I cant get a serial connection?
lannocm
Postby lannocm » Wed Feb 17, 2021 9:31 pm
I just found this post
https://www.esp32.com/viewtopic.php?t=6670
I didn't understand much of it but it seems to be saying it's possible to use psram as flash but difficult. Just asking the designer for his view. He seemed to be saying it could be used for both the camera and the MCU.
Just clutching at straws, really.
Users browsing this forum: ChatGPT-User, Google [Bot] and 8 guests
