How to work with multiple I2C RTOS tasks?
MikeLemon
Postby MikeLemon » Thu Feb 11, 2021 5:08 pm
Hi
I'm quite new to the whole make based programming and IDF migrating from the arduino world so,
I'm trying to drive an I2C display using the u8g2_hal library and ss1306 display with an I2C ADC in two separate tasks and it seems like after both tasks start the ESP32 crashed with this error log:
E (510) i2cdev: Could not read from device [0x48 at 0]: 263
E (510) ads111x: Could not read from register 0x01
I assume it's because the I2C display task tryes to use the bus while the adcRead task reads from it I've tries setting the I2C time out with :
    i2c_set_timeout(I2C_NUM_0, 100000 / portTICK_RATE_MS);
no luck there and I can't find any function that checks if the I2C bus is being used so how can this be dealt with?
allard
Re: How to work with multiple I2C RTOS tasks?
Postby allard » Fri Feb 12, 2021 12:06 pm
MikeLemon
Postby MikeLemon » Sun Feb 14, 2021 2:12 pm
I am using a binary mutex for the job but the I2C command probably works like shot and forget in the ESP32 meaning if I do u8g2_SendBuffer(&u8g2);
which updates the I2C display's buffer it still crashed before as after xSemaphoreGive(mutexBus); while updating the display it still uses the I2C for the display and runs it over with the I2C DAC communication.
Users browsing this forum: Baidu [Spider], Bing [Bot], Google [Bot], PerplexityBot and 3 guests
