Not able to program custom ESP32 board with FT232R USB to UART chip
pietnl
Postby pietnl » Mon Mar 01, 2021 7:04 pm
I recently had someone design a board for me that uses a ESP32-WROOM-32D and a FT232R USB to UART chip.
The idea was to make the board in such a way that it would be programmable using the EspTool.
Unfortunately, I'm unable to program the board. The only way I can program the board is by manually connecting GPIO0 to ground en than resetting the board (by connection EN to ground shortly)
According to the designer, this should not be necessary.
This is what the ESP and FT232R part of the circuit looks like:
usb to uart.PNG (47.49 KiB) Viewed 8821 times
There's no connection between EN/GPIO0 and the FT232R.
Most ESP32 board use DTR/RTS from the USB to UART chip to start the ESP32 in programming mode, I believe, usually with a schema like this:
prog circuit.PNG (5.53 KiB) Viewed 8821 times
But according to the designer, this should not be necessary when using the FT232R.
Can anybody give me advice on whether or not the extra piece of circuit using DTR and RTS is required to program the board?
WiFive
Re: Not able to program custom ESP32 board with FT232R USB to UART chip
Postby WiFive » Mon Mar 01, 2021 9:17 pm
You are right, he is wrong.
becorey
Postby becorey » Tue Mar 02, 2021 12:06 am
The esp32 needs a signal on GPIO0 to enter firmware download mode, and a toggle on EN/RESET to reset it and enter download mode. The FT232R could not magically do that over the TX/RX lines. Sorry, your designer was mistaken. Take a page from the many esp32 dev boards, use that auto flash circuit.
I like to use a part like UMH3N, the two transistors and resistors are in a single package, so it's just a single component to implement the auto flash function:
Postby Sprite » Tue Mar 02, 2021 6:01 am
Huh, that's a cute part; stashing that in the mental database for the next time I need it. Thanks for bringing it up.
pietnl
Postby pietnl » Tue Mar 02, 2021 7:07 pm
Thanks for the clarification!
The UMH3N looks like a great part to save some space, will give it a try!
Minatel
Postby Minatel » Tue Mar 02, 2021 7:29 pm
Better than my fellow BC847BS for almost the same price!
Users browsing this forum: Amazon [Bot], ChatGPT-User, PetalBot and 3 guests
