Hello folks, my name is Alexander and I am 24y old engineering student from germany.
I am currently working on a project where I use network compatible Arduinos some RGB LED's a button as well as an RFID-Module.
Because I want to upgrade this kind of protoyp I want to switch from Arduino to an ESP32 WROOM-E and use a costum PCB so that I dont have to do anymore soldering and can just order the boards online on Jlcpcb for example.
I first used an ESP32 DEV module to test if my code will work on an ESP and everything looks good for now (even tho I havent dont long termin and stability testing and stuff like this). Now I want to take the next step and start creating my own PCB schematics.
Where can I find informations about how to design a good and reliable schematics for my kind of stuff?
If I understood it right there are basicly 3 parts to get the ESP32 running:
Power supply
Micro Usb Connector
and USB to UART connector
(and my stuff like Pin header for the RFID Module, LEDs, etc.)
I also looked at the ESP32 Hardware Design Guidelines, but I dont want to start from scratch and just use a ESP32-WROOM-E module so the informations there do not really help me.
The main parts used in the most DEV-Kits are the AMS1117-3,3V for power supply and the CP2102N-A01-GQFN28 USB / UART connector.
Does it make sense to stick to these components for a custom design or are there better alternatives?
Shall I just try to copy the schematics from the devkit ? Are there any examples of good custom ESP32 designs?
For example a optimized power supply so the ESP works with cheap 5V Phone power supplys even on power consumption spikes.
greetings
Alexander
How to design a custom PCB with a ESP32 WROOM
alexander96
Re: How to design a custom PCB with a ESP32 WROOM
There are a lot of open source designs you can look at olimex, adafruit, sparkfun, m5stack, ...
alexander96
Hello as I cant really evalute the quality of those designs could you recommend me on concrete design which is probably close to what I need?
Best regards
Alexander
Best regards
Alexander
It really depends on what you need and what your other considerations are (size, availability of parts, power efficiency, ...). If you're happy with the DevkitC, just copy-pasta that design. If you need other specifics, look into parts or datasheets that have that.
