I recently purchased a new dev board - the Olimex ESP32 Gateway. I got the basic stuff running, but I am currently having issues with the ethernet part.
The following code works and I get an IP lease:
#include <stdio.h>
#include <string.h>
#include "freertos/task.h"
#include "tcpip_adapter.h"
#include "esp_netif.h"
#include "esp_eth.h"
#include "esp_event.h"
#include "esp_log.h"
#include "driver/gpio.h"
#include "sdkconfig.h"
static const char *TAG = "device";
/** Event handler for Ethernet events */
static void eth_event_handler(void *arg, esp_event_base_t event_base,
int32_t event_id, void *event_data)
uint8_t mac_addr[6] = {0};
/* we can get the ethernet driver handle from event data */
esp_eth_handle_t eth_handle = *(esp_eth_handle_t *)event_data;
switch (event_id) {
case ETHERNET_EVENT_CONNECTED:
esp_eth_ioctl(eth_handle, ETH_CMD_G_MAC_ADDR, mac_addr);
ESP_LOGI(TAG, "Ethernet Link Up");
ESP_LOGI(TAG, "Ethernet HW Addr %02x:%02x:%02x:%02x:%02x:%02x",
mac_addr[0], mac_addr[1], mac_addr[2], mac_addr[3], mac_addr[4], mac_addr[5]);
break;
case ETHERNET_EVENT_DISCONNECTED:
ESP_LOGI(TAG, "Ethernet Link Down");
break;
case ETHERNET_EVENT_START:
ESP_LOGI(TAG, "Ethernet Started");
break;
case ETHERNET_EVENT_STOP:
ESP_LOGI(TAG, "Ethernet Stopped");
break;
default:
break;
/** Event handler for IP_EVENT_ETH_GOT_IP */
static void got_ip_event_handler(void *arg, esp_event_base_t event_base,
ip_event_got_ip_t *event = (ip_event_got_ip_t *) event_data;
//const tcpip_adapter_ip_info_t *ip_info = &event->ip_info;
const esp_netif_ip_info_t *ip_info = &event->ip_info;
ESP_LOGI(TAG, "Ethernet Got IP Address");
ESP_LOGI(TAG, "~~~~~~~~~~~");
ESP_LOGI(TAG, "ETHIP:" IPSTR, IP2STR(&ip_info->ip));
ESP_LOGI(TAG, "ETHMASK:" IPSTR, IP2STR(&ip_info->netmask));
ESP_LOGI(TAG, "ETHGW:" IPSTR, IP2STR(&ip_info->gw));
void app_main() {
[color=#00BF00] tcpip_adapter_init();[/color]
[color=#FF0000] //ESP_ERROR_CHECK(esp_netif_init());[/color]
[color=#FF0000] //esp_netif_config_t cfg = ESP_NETIF_DEFAULT_ETH();
//esp_netif_t *eth_netif = esp_netif_new(&cfg);[/color]
ESP_ERROR_CHECK(esp_event_loop_create_default());
// Set default handlers to process TCP/IP stuffs
[color=#FF0000] //ESP_ERROR_CHECK(esp_eth_set_default_handlers(eth_netif));[/color]
[color=#00BF00] ESP_ERROR_CHECK(tcpip_adapter_set_default_eth_handlers());[/color]
ESP_ERROR_CHECK(esp_event_handler_register(ETH_EVENT, ESP_EVENT_ANY_ID, ð_event_handler, NULL));
ESP_ERROR_CHECK(esp_event_handler_register(IP_EVENT, IP_EVENT_ETH_GOT_IP, &got_ip_event_handler, NULL));
// MAC config
eth_mac_config_t mac_config = ETH_MAC_DEFAULT_CONFIG();
mac_config.smi_mdc_gpio_num = CONFIG_EXAMPLE_ETH_MDC_GPIO;
mac_config.smi_mdio_gpio_num = CONFIG_EXAMPLE_ETH_MDIO_GPIO;
//PHY config
eth_phy_config_t phy_config = ETH_PHY_DEFAULT_CONFIG();
phy_config.phy_addr = CONFIG_EXAMPLE_ETH_PHY_ADDR;
phy_config.reset_gpio_num = CONFIG_EXAMPLE_ETH_PHY_RST_GPIO;
//vTaskDelay(pdMS_TO_TICKS(10));
esp_eth_mac_t *mac = esp_eth_mac_new_esp32(&mac_config);
esp_eth_phy_t *phy = esp_eth_phy_new_lan8720(&phy_config);
esp_eth_config_t config = ETH_DEFAULT_CONFIG(mac, phy);
esp_eth_handle_t eth_handle = NULL;
ESP_ERROR_CHECK(esp_eth_driver_install(&config, ð_handle));
ESP_ERROR_CHECK(esp_eth_start(eth_handle));
}E (411) esp_netif_lwip: Cannot start esp_netif: Missing mandatory configuration:
esp_netif->driver_transmit: 0x0, esp_netif->driver_handle:0x0, esp_netif->lwip_input_fn: 0x400ecac0, esp_netif->lwip_init_fn:0x400ecb14
ESP_ERROR_CHECK failed: esp_err_t 0x103 (ESP_ERR_INVALID_STATE) at 0x40083fb0
Obviously, I would like to use the newer solution, as the other one is deprecated. Any ideas how to fix this?
