ESP32/UART : Buffer is null
Re: ESP32/UART : Buffer is null
i was using ESP32 wroom and stm32g431RB i was just using HAL uart liberary to sent At commands to ESp32 but im unable to read ok response from the esp32 ....are der any suggestions.
You're hijhacking a thread with your problem. Suggest you collect more information and start your own thread.
@ESP_Sprite.. So i did add '\0' at the end of the string but nothing changed, the serial monitor is always rubbish. what's weird to me is that i can see a response on the oscilloscope when i do an echo, so that means my esp32 is receiving correctly via rx buffer and write the data back via tx buffer.
Hm, dunno. Just for shits and giggles, can you post your current code again? Perhaps there's still something wrong with it.
#include <stdio.h>
#include <esp_vfs_fat.h>
#include <esp_modbus_slave.h>
#include <esp_err.h>
#include "UART.h"
void app_main() {
int uart_buffer_size = (1024*2);
const int uart_num = UART_NUM_2;
uart_config_t uart_config = {
.baud_rate = 115200,
.data_bits = UART_DATA_8_BITS,
.parity = UART_PARITY_DISABLE,
.stop_bits = UART_STOP_BITS_1,
.flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
//.rx_flow_ctrl_thresh = 122,
//.source_clk = UART_SCLK_APB,
// Configure UART parameters
uart_param_config(uart_num, &uart_config);
QueueHandle_t uart_queue;
uart_set_pin(uart_num, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
uart_driver_install(uart_num, uart_buffer_size, uart_buffer_size, 10, &uart_queue, 0);
uint8_t *data = malloc(uart_buffer_size);
while(1) {
int length;
length = uart_read_bytes(uart_num, data, 1,50 / portTICK_RATE_MS);
printf("%s", data);
if (length > 0) {
data[length] = '\0';
printf("%s", data);
fflush(stdout);
}Re: ESP32/UART : Buffer is null
uart_set_pin(uart_num, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);Re: ESP32/UART : Buffer is null
I have already specified them earlier but then I changed them into default hoping it could help!
You do printf("%s", data); twice, and the first time the data var still is not zero-terminated.
At the beginning, I was using only the second one (the one terminated with 0) but then I added the first one (before the while loop) just to compare.
Ok so I partially fixed the issue and now I can read the letter "p" that is being transmitting from a pic microcontroller. but I'm having this Guru meditation error after the buffer get full. I tried to flush after the loop but it didn't help. The code is below :
The error is :
I (518) RX_TASK: Read 1024 bytes: 'ppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppGuru Meditation Error: Core 0 panic'ed (IllegalInstruction). Exception was unhandled.
Core 0 register dump:
PC : 0x70707070 PS : 0x00050033 A0 : 0x70707070 A1 : 0x3ffb7150
A2 : 0x70707070 A3 : 0x70707070 A4 : 0x70707070 A5 : 0x70707070
A6 : 0x70707070 A7 : 0x70707070 A8 : 0x70707070 A9 : 0x70707070
A10 : 0x70707070 A11 : 0x70707070 A12 : 0x70707070 A13 : 0x70707070
A14 : 0x70707070 A15 : 0x3ffb7520 SAR : 0x00000004 EXCCAUSE: 0x00000000
EXCVADDR: 0x00000000 LBEG : 0x400014fd LEND : 0x4000150d LCOUNT : 0xfffffeff
Backtrace:0x7070706d:0x3ffb7150 |<-CORRUPTED
ELF file SHA256: fe7687a6cb18dc92
Rebooting...
#include "freertos/task.h"
#include "esp_system.h"
#include "esp_log.h"
#include "driver/uart.h"
#include "string.h"
#include "driver/gpio.h"
static const int RX_BUF_SIZE = 1024;
#define TXD_PIN (GPIO_NUM_4)
#define RXD_PIN (GPIO_NUM_5)
#define TXD_PIN (GPIO_NUM_18)
#define RXD_PIN (GPIO_NUM_19)
void init(void) {
const uart_config_t uart_config = {
//.flow_ctrl = UART_HW_FLOWCTRL_DISABLE,
// We won't use a buffer for sending data.
uart_driver_install(UART_NUM_1, RX_BUF_SIZE * 2, 0, 0, NULL, 0);
uart_param_config(UART_NUM_1, &uart_config);
uart_set_pin(UART_NUM_1, TXD_PIN, RXD_PIN, UART_PIN_NO_CHANGE, UART_PIN_NO_CHANGE);
static void rx_task(void *arg)
static const char *RX_TASK_TAG = "RX_TASK";
esp_log_level_set(RX_TASK_TAG, ESP_LOG_INFO);
uint8_t* data = (uint8_t*) malloc(RX_BUF_SIZE+1);
while (1) {
const int rxBytes = uart_read_bytes(UART_NUM_1, data, RX_BUF_SIZE, 1000 / portTICK_RATE_MS);
if (rxBytes > 0) {
data[rxBytes] = 0;
ESP_LOGI(RX_TASK_TAG, "Read %d bytes: '%s'", rxBytes, data);
//vTaskDelay(500);
ESP_LOG_BUFFER_HEXDUMP(RX_TASK_TAG, data, rxBytes, ESP_LOG_INFO);
free(data);
void app_main(void)
init();
xTaskCreate(rx_task, "uart_echo_task", 1024, NULL, 10, NULL);
}I (518) RX_TASK: Read 1024 bytes: 'ppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppppGuru Meditation Error: Core 0 panic'ed (IllegalInstruction). Exception was unhandled.
Rebooting...
Users browsing this forum: Baidu [Spider], Bing [Bot], Qwantbot and 2 guests
