ESP32 PWM Max frequency output
Minatel
Re: ESP32 PWM Max frequency output
Postby Minatel » Wed Apr 21, 2021 7:57 am
Can you check the output signal using a scope?
JKL@122JKL
Postby JKL@122JKL » Wed Apr 21, 2021 1:03 pm
I do not have the scope at the moment due to WFH.
I've checked voltage using a meter (average) value of 1.75V.
At this, I can hear a slow humming sound(turns on) from the Transducer but doesn't produce the vaporize effect.
I've changed the duty cycle value from the above code to 10, and even at higher voltage, still the same doesn't produce any.
ledcWrite(LEDC_CHANNEL_0, 10);
JKL@122JKL
Postby JKL@122JKL » Sat Apr 24, 2021 4:15 am
Can I try with varying frequency to check whether at particular freq inside a for loop or so?
JKL@122JKL
Postby JKL@122JKL » Mon Apr 26, 2021 6:35 am
Hi @ ESP_Minatel
From this board linked below, I removed an unknown uC PWM resistor to MOSFET and connected ESP32 PWM Output-113KHz 50% Duty cycle, even with that transducer turns on and no mist effect.
(https://robu.in/product/dc-5v-ultrasoni ... zing-chip/)
Users browsing this forum: Qwantbot and 3 guests
