Is it possible to use ESP-NOW and conenct to a WiFi network
hassan1551
Postby hassan1551 » Tue Apr 27, 2021 10:29 pm
I would like to ask some about something that did not work out for me. I am using PlatformIO. I have been trying to use one ESP32 to communicate with an ESP8266 using ESP-NOW and report back to a Wifi network that the ESP32 will connect to. This is a code that only initializes the ESP-NOW, without connecting to a Wifi network on the ESP32 board, it worked fine for me while communicating with the ESP8266:
Code: Untitled.cpp Select all
void setup() {
Serial.begin(9600);
WiFi.mode(WIFI_STA);
// Get Mac Add
Serial.print("Mac Address: ");
Serial.println(WiFi.macAddress());
// Initializing the ESP-NOW
if (esp_now_init() != 0) {
Serial.println("Problem during ESP-NOW init");
return;
esp_now_register_recv_cb(onDataReceiver);
esp_now_register_send_cb(onSent);
esp_now_peer_info_t* peer = new esp_now_peer_info_t;
memcpy(peer->peer_addr, slaveAddr, 6);
peer->channel = 4;
peer->encrypt = false;peer->ifidx = ESP_IF_WIFI_STA;
esp_now_add_peer(peer);
esp_now_send(slave1, dataToSend, sizeof(dataToSend));
Now, if I want it to connect to a network, I place the following line right before the "esp_now_init()", after adding this line, it successfully connects to the network, but the ESP-NOW stops sending nor receiving any messages :
WiFi.begin(networkSSID, networkPassword)
Here are my questions, is it even possible to connect to a Wifi network and use ESP-NOW at the same time? if it is possible, how can I get it to work? I am thankful for this forum and your hard work in it.
hassan1551
Re: Is it possible to use ESP-NOW and conenct to a WiFi network
Postby hassan1551 » Wed Apr 28, 2021 10:24 pm
It worked, but this is not what I need, I need to connect to a network, not create one and at the same time using the ESP-NOW
michikite
Postby michikite » Thu Apr 29, 2021 1:23 am
are you on the same wifi channel for esp-now and normal wifi?
I have not tried it myself, but I think that is a requirement. Then it should work.
impishbynature
Postby impishbynature » Thu May 20, 2021 7:26 am
My experience is that practical connection is diminished , a lot.
I now use two devices as standard, one for ESP-NOW and the other for TCP and link them by the serial TX/RX so they are each dedicated to one type of networking, makes a huge difference and is much cheaper if your time is worth anything.
