Help needed! WIFI Power is MAX on first WIFI STA following Power On Reset
FluxGS
Postby FluxGS » Thu Apr 29, 2021 6:31 pm
Thank you for looking, have unusual behavior for Power Up Reset (POR) Wifi Power.
I have set the WiFi power to 5 Db in MenuConfig.
I have Brownout Detector enabled.
After flashing the device, (POR), the first Wifi Start seems to be at max power and regularly trips the Brownout Detector.
If the Brownout (BO) detector does not trip, the first Wifi Start connects and disconnects normally. Once this first Wifi Start has executed, then the next Wifi Start draws much less power and there is never a BO event.
If the BO detector does trip on the first Wifi Start following powerup, then it is a cycle which never ends.
I have a BO reset, and on the next Wifi Start, it trips again. This repeats until a successful Wifi Start, then all subsequent Wifi Starts have low power.
In measurements:
Device Current (Wifi STA (1) following POR) is 250mA
Device Current (Wifi STA 2 - n) is 120mA
Is there a register which I can program before a Wifi Start that will set the initial Wifi STA to use the lower power setting?
I added to the code: esp_wifi_set_max_tx_power (); however it does not allow a call until after Wifi Start, which is too late.
Using esp_wifi_get_max_tx_power, following the successful Wifi Start, the return value is 5Db as expected.
Can someone recommend a method to force the first Wifi Start to use the lower power setting configured in Menuconfig?
Thank you for your review!
FluxGS
Re: Help needed! WIFI Power is MAX on first WIFI STA following Power On Reset
Postby FluxGS » Thu Apr 29, 2021 8:01 pm
WiFive,
Interesting link. Are you explaining that the full RF calibration that occurs following POR is driving the high power on the initial sequence?
If so, is this something that I can reduce?
Thank you for your contribution!
FluxGS
Postby FluxGS » Thu Apr 29, 2021 8:11 pm
very interesting point.
When looking at the monitor output, each time the current is high for Wifi Start, the statement:
W (15047) phy_init: failed to load RF calibration data (0x1102), falling back to full calibration
is present and when the Wifi Start current is low, this statement is not present.
Is there a way to conduct Full Calibration without high power?
Users browsing this forum: Semrush [Bot] and 9 guests
