What is the ESPtool command entry to return how much memory... ram, sram, flash memory, etc is on the Espressif ESP32 DevKit V4 board?
I just got ESPtool installed on a Win10 PC and a Linux Mint 20 machine and am learning how to use it.
From the command line I know...
> esptool.py --help
and...
>esptool.py chip_id
But I'm having trouble understanding all the
> esptool.py --help
results.
Thanks for any help.
ESPtool command to return Memory on ESP32 DevKit?
Re: ESPtool command to return Memory on ESP32 DevKit?
You can try:
esptool.py v3.1-dev
Serial port /dev/ttyUSB0
Connecting........_____....._____....._____.
Detecting chip type... ESP32
Chip is ESP32-D0WD-V3 (revision 3)
Crystal is 40MHz
MAC: fc:f5:c4:3c:62:90
Uploading stub...
Running stub...
Stub running...
Manufacturer: c8
Device: 4017
Detected flash size: 8MB
Hard resetting via RTS pin...
You can see the chip type, features and the detected flash size. For more details you can see by the module/chip datasheet.
You can try:
esptool.py -p <PORT> flash_idSerial port /dev/ttyUSB0
Crystal is 40MHz
Uploading stub...
Running stub...
Stub running...
Manufacturer: c8
Device: 4017
That did it.
Question Answered by by ESP_Minatel.
Thanks for the help.
Users browsing this forum: Amazon [Bot], Applebot, Google [Bot] and 2 guests
