Hi everyone,
I want to upload the code that I wrote in Arduino IDE to my ESP Dev Kit. But I don't want to use USB-mini. Instead, I want to use a USB-to-UART converter because I have developed my own board with ESP32 Microcontroller on it, and that board is tiny, and I don't want to deal with the soldering of the CP2102 component.
So, I bought a USB-to-UART converter that has CP2102 on it. Then I connected the pins like these:
Converter's 3.3V --------> ESP Dev Kit's 3.3V
Converter's GND --------> ESP Dev Kit's GND
Converter's RX --------> ESP Dev Kit's TX
Converter's TX --------> ESP Dev Kit's RX
After I connect them, I can see the port in my IDE, I upload the code, but it is stuck on the Connecting part. I push the boot(upload) button, but it doesn't cause anything. I try to push both buttons at the same time, but it doesn't work as well.
Do you have any suggestions for this situation?
Uploading Code By Using USB-to-UART to ESP Dev Kit
mustafaugur
Re: Uploading Code By Using USB-to-UART to ESP Dev Kit
The correct button trick is to press and hold 'BOOT', then press and release 'RST', then release 'BOOT'; as your setup lacks the auto-reset functionality, you'll have to do this every time. However, if you're using a devboard, an additional issue may be that the on-board USB-to-serial converter chips interferes with your external one. Suggest you look up the schematic for your devkit for that issue; at least our official devkits have resistors you can remove to isolate the RX/TX pins from the onboard CP210x.
mustafaugur
Thank you for your suggestion. But, I tried that first I removed the CP2102 chip on the Dev Kit and tried to upload my code to the Dev Kit but it didn't work. Also, I tried to upload the code in the way that you described in your first sentence it didn't work also. I will try to desolder the Esp controller chip and I will solder the RX, TX pins of it to the converter and try to upload the code again.
Were you ever able to find a solution to this question? I am having the same issue.
Okay, I found a solution.
I think the USB-UART controller is setting Rx to high. So just remove the resistors from Rx between the Wroom module and the USB-UART controller.
