I2C : why can't I send twice the same cmd ?
jmcornil
Postby jmcornil » Fri Apr 30, 2021 9:09 am
Hello
I have an issue with the i2c_master_cmd_begin() function.
I want to read the 14 data registers of an mpu_6050 (Acc_x, Acc_y, Acc_z, Temp, G_x, G_y, G_z).
So I make the following command :
   esp_err_t ret ;
   /// Buffer où mettre les 14 octets lus depuis le mpu
   uint8_t p_buff_raw_data[14];
   /// Préparation d'une commande lecture de 14 octets à partir de <ACCEL_XOUT_H_ADDR>
   /// Création d'un variable (handler) <cmd_read_14_AccX> grâce auquel on va construire */
   i2c_cmd_handle_t cmd_read_14_AccX = i2c_cmd_link_create();
   /// Signal <START>  (voir description I2C)
   i2c_master_start(cmd_read_14_AccX);
   /// Adresse du périphérique (écriture)
   i2c_master_write_byte(cmd_read_14_AccX, 0x68 << 1, ACK_CHECK_EN);
   /// Adresse du premier registre
   i2c_master_write_byte(cmd_read_14_AccX, 0x3B, ACK_CHECK_EN);
   /// Nouveau signal <START>
   /// Adresse du périphérique (lecture)
   i2c_master_write_byte(cmd_read_14_AccX, (0x68 << 1)|I2C_MASTER_READ, ACK_CHECK_EN);
   /// Lecture de 13 octets  avec un signal <ACK> en retour
   i2c_master_read(cmd_read_14_AccX, p_buff_raw_data, 13, ACK_VAL);
   /// Lecture du 14-èmè avec un signal <NACK> en retour
   i2c_master_read_byte(cmd_read_14_AccX, p_buff_raw_data+13, NACK_VAL);
   /// Signal <STOP>
   i2c_master_stop(cmd_read_14_AccX);vTaskDelay(100);
If then I run :
   ret = i2c_master_cmd_begin(0, cmd_read_14_AccX , 1000 / portTICK_RATE_MS);
   printf("*** (1) * err retour = %i \r\n",ret);
it works fine and I get ret= ESP_OK
Since I want to read these registers again and again, I tought that I could use the same cmd_read_14_AccX without deleting and rebuildind it. But If i execute twice i2c_master_cmd_begin() with the same cmd_read_14_AccX :
   vTaskDelay(100);
   printf("*** (2) * err retour = %i \r\n",ret);
the second time I get ret=-1 and I don't understand why.
Moreover the I2C seems blocked and I have to unplug the device before getting another correct read.
Any hint ?
Thanks in advance.
I am working with : esp-idf v4.1-dev-2020-ga7bbc74a2-dirty
jakob
Re: I2C : why can't I send twice the same cmd ?
Postby jakob » Thu May 06, 2021 1:42 am
Hi jmcornil,
we had some issues with re-using the I2C commands. I personally don't know the details but for now, please create a new I2C command for every transaction.
Best,
Jakob
morris
Postby morris » Thu May 06, 2021 3:03 am
no, we can't reuse the i2c_cmd_handle_t after i2c_master_cmd_begin, which will change the internal state of i2c_cmd_handle_t.
jmcornil
Postby jmcornil » Thu May 06, 2021 9:14 am
Thank you for your replies.
However I think it would be writtent in the documetation page https://docs.espressif.com/projects/esp ... TickType_t that there is a side effect on the cmd_handle argument and it is no more usuable for a next call.
Users browsing this forum: Amazon [Bot], PerplexityBot and 6 guests
