Working temperature and WiFi transmission
Die_32_
Postby Die_32_ » Tue May 11, 2021 8:20 am
Does the ESP32-WROOM-32UE has a kind of thermal shutdown for the Wifi transmission ?
It seems that if ambient temperature is greater than 85 °C it stops the Wifi transmission, until it reachs (more or less) 25 °C ambient temperature.
Does it has a kind of thermal protection ?
Re: Working temperature and WiFi transmission
Postby Sprite » Tue May 11, 2021 8:27 am
Do you specifically have the high-temperature version of that chip? The 'normal' version is only specified up till 85C. (Also, what do you mean with 'stops the wifi transmission'? What does the software do at that point?)
Die_32_
Postby Die_32_ » Tue May 11, 2021 9:31 am
It seems that the module itself stops the Wifi transmission, until it cool down itself.
Could it be ?
WiFive
Postby WiFive » Tue May 11, 2021 11:07 pm
What does the log say
Die_32_
Postby Die_32_ » Wed May 12, 2021 7:28 am
I do not have any logs, I'm actually wondering if there is this kind of themperature protection on the ESP32 ?
Postby Sprite » Thu May 13, 2021 1:39 am
No, there is not, hence us asking for the logs
Users browsing this forum: markkuk and 1 guest
