ESP32 keypad strange behavior: some kind of pin combination doesn't work.
DirectionLee
Postby DirectionLee » Sun May 16, 2021 1:57 pm
I'm trying to test keypad with ESP32. the keypad is 4*4, I tried some of combination of pin setting, some of combination works but some fails.
#include <Wire.h>
#include <Keypad.h>
const byte ROWS = 4;
const byte COLS = 4;
char keys[ROWS][COLS] = {
    {'1','2','3','A',},
    {'4','5','6','B',},
    {'7','8','9','C',},
    {'*','0','#','D',},
byte rowPins[ROWS] = {14, 27, 26,25};
byte colPins[COLS] = {4, 16, 17, 5,};
Keypad keypad = Keypad( makeKeymap(keys), rowPins, colPins, ROWS, COLS );
void setup()
  Serial.begin(115200);
  keypad.addEventListener(mykeypadEvent);
void mykeypadEvent(KeypadEvent key){
  Serial.printf("in event, key: %d, state=%d\n", key,keypad.getState());
void loop()
  char key = keypad.getKey();
  if (key != NO_KEY)
  	Serial.printf("key: %c pressed\n", key);
this combination works:
byte rowPins[ROWS] = {26,25,33,32};
byte colPins[COLS] = {15,2,0,4};
this combination fails, seems pin16, pin17
byte colPins[COLS] = {4,16,17,5};
could anyone know the reason why 2nd combination failed?
WiFive
Re: ESP32 keypad strange behavior: some kind of pin combination doesn't work.
Postby WiFive » Sun May 16, 2021 7:28 pm
What hardware?
Postby Sprite » Mon May 17, 2021 1:49 am
To add to WiFive's (terse as usual) response: if your hardware has PSRAM, you cannot use GPIO16/17.
DirectionLee
Postby DirectionLee » Sun May 23, 2021 12:32 pm
thank you, guys, you are right. the hardware is ESP32 devkitC (ESP32-WROVER-IE), so pin16,17 is reserved for internal use, I forgot this one. thank you again.
Users browsing this forum: meta-externalagent, Qwantbot and 2 guests
