I made a mesh network with three esp32 devices using the painlessMesh.h library and everything is working fine.
When I connect only one esp32 to the wifi network, it often doesn't respond to the ping for several seconds.
What can it be?
mesh network + wifi
lbernstone
Re: mesh network + wifi
The first problem was my fault, I was using bad a library.
I have created a mesh network with some esp32 devices.
The master device connects to the main wifi and communicates with the other mesh devices.
The maximum number of nodes is 10, so if I want to add other devices I have to create an additional root node that acts as a bridge.
Unfortunately I can't find any documentation about it. I'm using the Arduino IDE and I can't find any procedures on the library that help me.
