I'm looking for a solution to run two network interfaces on a esp32-s2 with DHCP server support.
Scenario:
- interface 1 is usb cdc-ecm (could be ethernet as well) - subnet 192.168.1.x
- interface 2 is WiFi - subnet 192.168.2.x
Both shall support a DHCP server.
Hence I enabled DHCP server inside esp-idf.
However as I checked the dhcp_server_start function, I found no option to start it for both interfaces.
Furthermore there is no multi instance support inside of the DHCP server module - at least to my understanding.
Question:
Can anyone give me some pointers how to do that?
Is there an already available solution for this?
Do I need to extend the DHCP server module?
Many thanks in advance,
Torsten
Two NetIf with one DHCP server instance
BenSuffolk
Re: Two NetIf with one DHCP server instance
Did you find a solution?
I’m wanting to run a dhcp server on an Ethernet interface and have the softAP WiFi enabled. I have found that when I do this the Ethernet interface no longer issues dhcp addresses. When you connect to the soft ap I see the logs issue 2 identical ip addresses. So clearly the server is still running twice, but they are then both bound to the soft ap.
unfortunately no solution yet.
As far as I know the dhcp server - currently available - can not handle different sub-networks yet.
Hence somebody need to improve the dhcp server.
Regards Torsten
Regards Torsten
Users browsing this forum: Amazon [Bot] and 7 guests
