I have designed a smart home switch board based on ESP32-WROVER-B(16), TTP223 & CAP1114 for touch switch, SSD Relay & TP6505 IC for Mobile charging, i am uploading the schematic and PCB files,
Frontboard PC is detecting board can uplaod any program but ESP32 goes in boot loop, unstable.
Backpanel board is not getting enough power by HLK-40M12 then LM2596T 5.0V, some Solid State Relay is on by default and some are not supplying output even HIGH by command.
need help
Any ESP32 example codes i uploads noting happens on serial monitor & after pressing Reset button it gives the same error on every code
Error code on Serial Monitor
rst:0x1 (POWERON_RESET),boot:0x3 (DOWNLOAD_BOOT(UARz⸮IQ⸮/SDIO_REI_REO_V2))
waiting for download
ets Jun 8 2016 00:22:57
The example code is
#include <WiFi.h>
#include "time.h"
const char* ssid = "Aadi2910";
const char* password = "Stuti0908";
const char* ntpServer = "pool.ntp.org";
const long gmtOffset_sec = 3600;
const int daylightOffset_sec = 3600;
void printLocalTime()
struct tm timeinfo;
if(!getLocalTime(&timeinfo)){
Serial.println("Failed to obtain time");
return;
Serial.println(&timeinfo, "%A, %B %d %Y %H:%M:%S");
void setup()
Serial.begin(115200);
//connect to WiFi
Serial.printf("Connecting to %s ", ssid);
WiFi.begin(ssid, password);
delay(500);
Serial.print(".");
Serial.println(" CONNECTED");
//init and get the time
configTime(gmtOffset_sec, daylightOffset_sec, ntpServer);
printLocalTime();
//disconnect WiFi as it's no longer needed
WiFi.disconnect(true);
WiFi.mode(WIFI_OFF);
void loop()
delay(1000);
printLocalTime();
Smart Home Switch Board
- Schematic_frontboard.pdf
- (70.85 KiB) Downloaded 306 times
- Schematic_back panel.pdf
- (183.55 KiB) Downloaded 314 times
Users browsing this forum: Semrush [Bot] and 1 guest
