rtc_clk_apll_enable函数调用失败
www220
Postby www220 » Sun Apr 16, 2017 9:14 am
总是处于循环中无法结束
/* wait for calibration end */
while (!(I2C_READREG_MASK_RTC(I2C_APLL, I2C_APLL_OR_CAL_END))) {
/* use ets_delay_us so the RTC bus doesn't get flooded */
ets_delay_us(1);
请问如何解决
igrr
Re: rtc_clk_apll_enable函数调用失败
Postby igrr » Sun Apr 16, 2017 9:25 am
Thanks for the report. What argument values are you passing to rtc_clk_apll_enable?
www220
Postby www220 » Sun Apr 16, 2017 11:23 am
rtc_clk_apll_enable(true, 0, 0, 1, 0);
REG_SET_FIELD(RTC_CNTL_ANA_CONF_REG, RTC_CNTL_PLLA_FORCE_PD, enable ? 0 : 1);
类似这个寄存器操作不正确,但是又没有寄存器说明
igrr
Postby igrr » Sun Apr 16, 2017 3:52 pm
It should probably be
    SET_PERI_REG_BITS(RTC_CNTL_ANA_CONF_REG, 1, enable ? 0 : 1, RTC_CNTL_PLLA_FORCE_PD_S);
    SET_PERI_REG_BITS(RTC_CNTL_ANA_CONF_REG, 1, enable ? 1 : 0, RTC_CNTL_PLLA_FORCE_PU_S);
    SET_PERI_REG_BITS(RTC_CNTL_OPTIONS0_REG, 1, enable ? 0 : 1, RTC_CNTL_BIAS_I2C_FORCE_PD_S);
instead.
www220
Postby www220 » Mon Apr 17, 2017 1:53 am
instead.
不单单是这几个寄存器,这三个寄存器的值我修改过,但是仍然无法跳出循环,可能还有其他地方类似需要使能的时候,用错函数,导致寄存器操作失败
igrr
Postby igrr » Mon Apr 17, 2017 9:09 am
With the above change rtc_clk_apll_enable works well both on rev0 and rev1 chips.
The reason why rtc_clk_apll_enable(true, 0, 0, 1, 0) doesn't work is that the arguments don't meet the range given in the function documentation:
apll_freq = xtal_freq * (4 + sdm2 + sdm1/256 + sdm0/65536)/((o_div + 2) * 2)
The dividend in this expression should be in the range of 240 - 600 MHz.
With sdm2 = 1, the dividend is 200 MHz.
WiFive
Postby WiFive » Mon Apr 17, 2017 9:35 am
So for 50mhz we want rtc_clk_apll_enable(true, 0, 0, 6, 2)?
igrr
Postby igrr » Mon Apr 17, 2017 10:05 am
That's correct, rtc_clk_apll_enable(true, 0, 0, 6, 2) gives 50 MHz output.
www220
Postby www220 » Mon Apr 17, 2017 4:28 pm
已经搞定万分感谢
BuddyCasino
Postby BuddyCasino » Tue Apr 18, 2017 7:21 am
@ESP_igrr: I saw the new sources for clock management (https://github.com/espressif/esp-idf/bl ... clk.c#L120), its for I2C and not for I2S, right?
Users browsing this forum: meta-externalagent, Qwantbot and 2 guests
