SD CARD DRIVER WITH SDIO
amalamal
Postby amalamal » Tue Apr 18, 2017 12:36 pm
Hi
Anyone have the driver for SD card with SDIO protocol with a pinout of GPIO6,7,8,9,10,11
ESP_igrr
Re: SD CARD DRIVER WITH SDIO
Postby ESP_igrr » Tue Apr 18, 2017 12:46 pm
ESP-IDF has the SDMMC driver which can use these pins (you need to use slot = SDMMC_HOST_SLOT_0 in sdmmc_host_t structure to use it).
Note however that these pins are normally used by the SPI flash. It is only possible to use SDMMC on these pins if SPI flash is assigned to other pins. This can configured using EFUSEs.
amalamal
Postby amalamal » Tue Apr 18, 2017 1:37 pm
Hi ESP_igrr
Thanks for the reply, I changed the slote 1 to slote 0 in sdmmc_host_t structure .
As per your suggestion
" It is only possible to use SDMMC on these pins if SPI flash is assigned to other pins"
could you please tell me how to assign the SPI flash to other pins?
adamtegen
Postby adamtegen » Wed Aug 01, 2018 10:53 pm
I am also curious on how to assign SPI flash to other pins. I'm looking to use 2 SD cards, one each on _0 and _1.
ESP_igrr
Postby ESP_igrr » Thu Aug 02, 2018 7:15 am
SPI flash can be remapped to other pins by burning EFUSEs of the ESP32. "espefuse.py" tool which comes with IDF can be used for this purpose. Please see
https://github.com/espressif/esptool/wi ... flash-pins
Users browsing this forum: Bing [Bot], PerplexityBot, Qwantbot and 4 guests
