noise is corrected to nice ?
DutchOrange
Postby DutchOrange » Tue Jun 29, 2021 5:53 pm
So I was trying to use the noise function form FastLED. Here is my code
This is ESP-IDF 4.2
On a Windows machine
#include "mdf_common.h"
#include "mwifi.h"
#include <freertos/FreeRTOS.h>
#include <freertos/task.h>
#include <stdio.h>
#include <led_strip.h>
#include <noise.h>
void app_main(void)
    while(1){
         noise(5,7);
        //printf("Hello world  %f \n", noise_values);
        vTaskDelay(1000 / portTICK_RATE_MS);
But when I run this code I get the error of:
../main/buzzer.c:38:10: error: implicit declaration of function 'noise'; did you mean 'nice'? [-Werror=implicit-function-declaration]
          noise(5,7);
          nice
cc1.exe: some warnings being treated as errors
[13/20] Performing build step for 'bootloader'
[0/1] Re-running CMake...
CMake Warning at D:/ESP-MDF/esp-mdf/esp-idf/tools/cmake/idf.cmake:18 (message):
  IDF_PATH environment variable is different from inferred IDF_PATH.
                              Check if your project's top-level CMakeLists.txt includes the right
                              CMake files. Environment IDF_PATH will be used for the build:
                              D:/ESP-IDF
  D:/ESP-MDF/esp-mdf/esp-idf/tools/cmake/project.cmake:7 (include)
  CMakeLists.txt:20 (include)
Any ideas why ?
Thanks for any help.
Stephan
Re: noise is corrected to nice ?
Postby Stephan » Tue Jun 29, 2021 10:05 pm
Because there is no function "noise()" declared in noise.h. Therefore, the symbol noise() is unknown. See the available functions in https://github.com/hpwit/fastled-esp32- ... er/noise.h Depending on what you want to achieve, pick one of these functions. This has nothing to do with IDF 4.2 or Espressif in general. It is a general C question.
DutchOrange
Postby DutchOrange » Wed Jun 30, 2021 1:25 pm
Thanks, found out this morning of my stupid mistake,
Corrected it to
inoise8_2d()
Users browsing this forum: Bing [Bot], ChatGPT-User, Google [Bot], PetalBot and 1 guest
