Sample using Elliptic curve cryptography with micro-ecc and ESP32 hardware enabled cryptography aes (256 bits, Counter Mode (CTR)) and sha (SHA-256) hash:
https://github.com/pcbreflux/espressif/ ... _micro-ecc
ESP32 Elliptic curve cryptography with micro-ecc, aes, sha example
- micro-ecc.png (172.6 KiB) Viewed 13771 times
Re: ESP32 Elliptic curve cryptography with micro-ecc, aes, sha example
Hi pcbreflux,
this is really cool.
Please, more of those examples.
Something like reading from an uart (e.g. rfid rdm6300 keys) and sending it as encrypted mqtt messages via wifi to a mosqitto server.
Keep on publishing.
Best regards.
DL88AI88
Keep on publishing.
Best regards.
DL88AI88
Hi DL88AI88,
thanks. Coincidentally i published a new secure MQTT example on github yesterday.
With MQTT via SSL/TLS (also hardware encrypted) and Websocket -> testing my secured mosquitto servers on UBUNTU and Raspberian.
-> Part of my /etc/mosquitto/mosquitto.conf
ESP32 example:
https://github.com/pcbreflux/espressif/ ... mqtts_gpio
But i will try an example with "secure" bluetooth in the future.
listener 9883
protocol websockets
cafile /etc/mosquitto/certs/ca.crt
certfile /etc/mosquitto/certs/server.crt
keyfile /etc/mosquitto/certs/server.key
I (50036) MQTTS: MQTTClientInit ESP32MQTTE2F9A905
I (50036) MQTTS: MQTTConnect ...
I (50256) MQTTS: MQTTSubscribe ...
I (50456) MQTTS: MQTTYield ...
I (104616) MQTTS: Topic received!: esp32/bulb1/1 32
I (104616) MQTTS: setLED!: 18 1 32 1 13
I (134726) MQTTS: Topic received!: esp32/bulb1/4 40
I (134726) MQTTS: setLED!: 22 4 40 4 13
I (149196) MQTTS: Topic received!: esp32/bulb1/5 40
I (149196) MQTTS: setLED!: 22 4 40 5 13
I (160276) MQTTS: Topic received!: esp32/bulb1/7 40
I (160276) MQTTS: setLED!: 22 4 40 7 13
I (172156) MQTTS: Topic received!: esp32/bulb1/7 100
I (172156) MQTTS: setLED!: 22 4 100 7 13
I (180026) MQTTS: Topic received!: esp32/bulb1/0 100
I (180026) MQTTS: setLED!: 5 0 100 0 13
I (189086) MQTTS: Topic received!: esp32/bulb1/0 140
I (189086) MQTTS: setLED!: 5 0 140 0 13
Is this similar to STSAFE-A100 but without the dedicated hardware IC?
https://www.st.com/en/secure-mcus/stsafe-a100.html
I am looking to add STSAFE-A100 module for my device for Unique deviceID, authentication, TLS and also for saving credentials. The device would be connected and managed by Microsoft Azure including OTA.
