ESP32-S2 USB Host CDC问题
Moderator: Bob
Re: ESP32-S2 USB Host CDC问题
I just updated usb component in that repository and now it builds, please try again.
lightsaltsign
still build errorI just updated usb component in that repository and now it builds, please try again.
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/cdc_class.c: In function 'cdc_create_pipe':
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/cdc_class.c:129:40: error: 'USB_XFER_TYPE_INTR' undeclared (first use in this function); did you mean 'USB_TRANSFER_TYPE_INTR'?
if(USB_DESC_EP_GET_XFERTYPE(ep) == USB_XFER_TYPE_INTR){
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/cdc_class.c:129:40: note: each undeclared identifier is reported only once for each function it appears in
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/cdc_class.c:132:47: error: 'USB_XFER_TYPE_BULK' undeclared (first use in this function); did you mean 'USB_TRANSFER_TYPE_BULK'?
} else if(USB_DESC_EP_GET_XFERTYPE(ep) == USB_XFER_TYPE_BULK && USB_DESC_EP_GET_EP_DIR(ep)){
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/main.c: In function 'usbh_set_address_cb':
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/main.c:99:18: error: implicit declaration of function 'hcd_pipe_update'; did you mean 'hcd_pipe_update_mps'? [-Werror=implicit-function-declaration]
if(ESP_OK != hcd_pipe_update(ctrl_pipe_hdl, DEVICE_ADDR, bMaxPacketSize0)) ESP_LOGE("", "failed to update ctrl pipe");
hcd_pipe_update_mps
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/main.c: In function 'usbh_port_connection_cb':
/Users/lvfeng/trunk/esp-refs/esp32-s2-usb-host-cdc/main/main.c:145:22: warning: unused variable 'state' [-Wunused-variable]
hcd_port_state_t state;
looking forwards for your reply
