32kHz oscillator on ESP-WROVER-KIT-VE not working
istokm
Re: 32kHz oscillator on ESP-WROVER-KIT-VE not working
Postby istokm » Sun Jul 11, 2021 11:36 pm
Sometimes I don't see the "BTDM_INIT: 32.768kHz XTAL not detected" message, but the 32.768k clock is unstable and causes the board to usually crash when entering light sleep.
I can confirm the exact same findings. I was not the one who tested the 10M resistor, a colleague did, but reported no change at all in the boards behaviour - though I haven't reported this because we didn't yet test this on the WROVER board, but a custom one.
As to the unstable clock, this only happened to me if I pushed the calibration cycles to a absurdly high value (8K+) & the board probably thought that the clock was running. This would either lead to RTCWDT panics (or something similar, I don't remember the name from heart), boards not waking up from a timed deep sleep, or something similar.
We'll continue to debug this, but as a simple sure fix (for custom boards), I would suggest just eating the cost of a MEMS oscillator instead of dealing with undocumented hardware requirements - this is our fallback plan as well, as we've been able to demonstrate that an external clock (ex. function generator) works reliably.
therealergo
Postby therealergo » Mon Jul 12, 2021 4:26 pm
I've re-tested everything on the WROVER-KIT with the 10M resistor between XN and XP, and it's been reliably running for an entire day now. (!!!) Maybe the flux/alcohol on the resistor hadn't fully dried when I first tested it. The XN/XP differential on the WROVER-KIT looks something like this, constantly:
Unfortunately, the behaviour is still the same on the custom boards with either no resistor, a 10M resistor, or a 5M resistor. Looking at the scope, the oscillation slowly dies out over a couple seconds:
As a simple sure fix (for custom boards), I would suggest just eating the cost of a MEMS oscillator instead of dealing with undocumented hardware requirements
A good idea, but I want to avoid that cost if at all possible :)
Considering that it now seems to be working for me on the WROVER-KIT, I'd think that this is solvable.
m.madela
Postby m.madela » Sun Aug 08, 2021 10:54 am
the 10Mohm register in parallel to quartz works for me, thank you
johnboiles
Postby johnboiles » Fri Mar 04, 2022 1:15 am
So is it a bug in the hardware design that this 10M resistor isn't included on the PCB? The onboard crystal is useless without it right?
The hardware design guidelines (https://www.espressif.com/sites/default ... nes_en.pdf) seem to confirm it's necessary:
When ESP32-D0WD-V3 connects to an external 32.768 kHz crystal, the parallel resistor must be populated.
Users browsing this forum: markkuk, PetalBot, trendictionbot and 1 guest
