I would like to communicate with an external web server from the ESP32. However, we need to be able to do this via an external cellular modem that provides a raw socket interface (we already have a network stack that provides this).
It looks like the HttpClient library (https://docs.espressif.com/projects/esp ... lient.html) is hardcoded to use the Wi-Fi connection but I'm wondering if I'm missing a trick and there is some way to intercept the low-level socket open/read/write calls to allow use of an alternate transport?
Another possibility would be to port something like the mbed http library (https://os.mbed.com/cookbook/HTTP-Client) but I'd much rather use the built-in libraries if possible.
(Yet another approach would be to use the on-board _cellular_ support for HTTP connections but this leads to a scenario where we're using HttpClient for Wi-Fi connections and a completely different stack for cellular connections which is undesirable for testing.)
Any ideas ?
Thanks,
Neil
Using httpclient libraries with custom transport
Neil.Macmullen
Users browsing this forum: Bing [Bot], ChatGPT-User, PerplexityBot, Qwantbot and 1 guest
