About the CAN controller.
jcsbanks
Re: About the CAN controller.
Postby jcsbanks » Wed Apr 05, 2017 12:36 pm
It is working with MCP2551.
Kvaser log, I sent 8 zeros in the first three packets, then 0, 52 then six zeroes in the subsequent packets and the ESP32 echoes them.
The 2018 is the CAN ID, 8 is the DLC, then the payload, then the timestamp and Transmit or Receive.
 0        2018         8   0   0   0   0   0   0   0   0      66.129150 T
 0        2018         8   0   0   0   0   0   0   0   0      66.133580 R
 0        2018         8   0   0   0   0   0   0   0   0      76.258980 T
 0        2018         8   0   0   0   0   0   0   0   0      76.263080 R
 0        2018         8   0   0   0   0   0   0   0   0      80.845390 T
 0        2018         8   0   0   0   0   0   0   0   0      80.853070 R
 0        2018         8   0  52   0   0   0   0   0   0      87.391740 T
 0        2018         8   0  52   0   0   0   0   0   0      87.393020 R
 0        2018         8   0  52   0   0   0   0   0   0      89.739940 T
 0        2018         8   0  52   0   0   0   0   0   0      89.743010 R
 0        2018         8   0  52   0   0   0   0   0   0      90.887330 T
 0        2018         8   0  52   0   0   0   0   0   0      90.893050 R
 0        2018         8   0  52   0   0   0   0   0   0      92.257020 T
 0        2018         8   0  52   0   0   0   0   0   0      92.262990 R
 0        2018         8   0  52   0   0   0   0   0   0      93.409870 T
 0        2018         8   0  52   0   0   0   0   0   0      93.413030 R
 0        2018         8   0  52   0   0   0   0   0   0      94.374990 T
 0        2018         8   0  52   0   0   0   0   0   0      94.383010 R
What is interesting is the round trip time varies from 1ms to 8ms. 500kbps bus, nothing else on the bus. Any ideas on getting the latency lower? It isn't bad, but my 180MHz ECU usually replies in 1ms to Kvaser.
Getting rid of printf and changing
if(xQueueReceive(CAN_cfg.rx_queue,&__RX_frame, 3*portTICK_PERIOD_MS)==pdTRUE){
to
if(xQueueReceive(CAN_cfg.rx_queue,&__RX_frame, 1*portTICK_PERIOD_MS)==pdTRUE){
doesn't change it.
ThomasB
Postby ThomasB » Wed Apr 05, 2017 4:41 pm
While the rx frame is handled in an ISR, the tx frame is send in a task context. As we have plenty of tasks for wifi etc. you can not know if there are currently higher priority tasks pending and as the tx task has no synchronisation point, the delay jitters.
You can place the tx directly in the rx is context or try to increase the tx task priorit to remove or reduce jitter.
jcsbanks
Postby jcsbanks » Sat Apr 15, 2017 7:30 pm
First eight packets are with a FreeRTOS task replying with an echo of packets received, so four are sent, four received. Second eight packets are with the reply in an ISR. Moving from FreeRTOS to an ISR drops the latency 20 times from average of 5.3ms to 260us.
Fusion
Postby Fusion » Wed Apr 26, 2017 3:38 pm
Hi guys.
Just to confirm:
Wroom32 GPIO5 <---------> CAN TXD (D)
Wroom32 GPIO4 <---------> CAN RXD (R)
Is this correct?
Postby rudi ;-) » Wed Apr 26, 2017 4:27 pm
Hi guys.
Just to confirm:
Is this correct?
In relation to the nature of the question, first,
how you want drive CAN on ESP32?
MCP2551, TJA1051, SN65HVD233
5V / 3.7V / 3.3V
cause ESP32 is 3.3V - be sure your Receive Lines are LevelShifted to 3.3V
example MCP2551 is 5V and on Rx Line, this comes from MCP2551 and goes to ESP32 GPIO PIN; without a resistor / levelshift this can destroy your gpio cause 5V line....
.. there are several examples how you can do 5V Transceiver to a 3.3V Controller
example look how olimex this do..
or you can use 3.3V CAN Transceiver example sn65hvd233.
to your question itself:
how you set it you can use it
example in code..
CAN_device_t CAN_cfg = {
	.speed=CAN_SPEED_125KBPS,		// CAN Node baudrade
	.tx_pin_id = GPIO_NUM_5,		// CAN TX pin
	.rx_pin_id = GPIO_NUM_4,		// CAN RX pin
	.rx_queue=NULL,					// FreeRTOS queue for RX frames
third party CAN driver
example in menuconfig
edit:
my favority own circuit MCP2551 and ESP32 is this
Fusion
Postby Fusion » Wed Apr 26, 2017 6:17 pm
Thanks for the info. I will be using the SN65HVD230.
Any idea when Can support will be available in ESP32 Arduino?
santanapablo1975
Postby santanapablo1975 » Fri May 05, 2017 1:11 pm
Hi Thomas and Rudi!
Thanks for the sources around CAN, I made a test with success, 2 ESP32 tx and rx the test frame!
Regards
Bis dann denn!
MfG
Juan
Beck-Sisyphus
Postby Beck-Sisyphus » Thu May 11, 2017 10:57 am
Hi Rudi and Thomas,
It's great that you complete the CAN bus driver for ESP32!
When I configure the driver with different pinout, in my case is GPIO5->CAN TX and GPIO16->CAN RX, the menuconfig shows they are invalid pins. Running the code on both device successfully, but no communication yet. Is there a way to change the GPIO pinout for CAN bus?
Platform: ESP-IDF
Board: ESP-WROOM-32
CAN Transceiver: SN65HVD232 (3.3V)
Termination: 120 Ohm
Another question is about CAN bus protocol itself. Currently I planned to have one masters on the bus and two slaves, with masters and slaves both sending and receiving. How to define the address of the three device?
Thanks,
Beck
Screen Shot 2017-05-11 at 6.50.31 PM.png (44.39 KiB) Viewed 38455 times
Postby rudi ;-) » Thu May 11, 2017 11:45 am
it is cause the pins are selected as "Valid pins" in the menuconfig file for CAN-
feel free to set your own "Valid" config on this
change here the "valid pins" and here
4 and 5 are the successfully tested pins,
you can use other too
Platform: ESP-IDF
Board: ESP-WROOM-32
yes. see the preview text.
you can set example "itself" node
and send the message by using this itself node address.
example a "slave" - i will named it as CAN-Unit
send the ADC Value of one ADC Pin
and use the itself node address for the frame for this.
( the frame content not a delivery ( "Receiver" ) address, the frame content the "Transceiver" )
this is the base of CAN.
example with an counter :
void task_CAN_TX(void* pvParameters) {
   CAN_frame_t __TX_frame;
   uint32_t counter = 0;
      __TX_frame.MsgID = CONFIG_ESP_CAN_NODE_ITSELF; // address from menuconfig set
      __TX_frame.DLC   =  8;
      __TX_frame.data.u8[0] = 'E';
      __TX_frame.data.u8[1] = 'S';
      __TX_frame.data.u8[2] = 'P';
      __TX_frame.data.u8[3] = '-';
      __TX_frame.data.u8[4] = 'C';
      __TX_frame.data.u8[5] = 'A';
      __TX_frame.data.u8[6] = 'N';
      __TX_frame.data.u8[7] = counter;
while(1) {
      CAN_write_frame(&__TX_frame);
/*      printf("Frame from : 0x%08x, DLC %d \n", __TX_frame.MsgID, __TX_frame.DLC);
      printf("D0: 0x%02x, ", __TX_frame.data.u8[0]);
      printf("D1: 0x%02x, ", __TX_frame.data.u8[1]);
      printf("D2: 0x%02x, ", __TX_frame.data.u8[2]);
      printf("D3: 0x%02x, ", __TX_frame.data.u8[3]);
      printf("D4: 0x%02x, ", __TX_frame.data.u8[4]);
      printf("D5: 0x%02x, ", __TX_frame.data.u8[5]);
      printf("D6: 0x%02x, ", __TX_frame.data.u8[6]);
      printf("D7: 0x%02x\n", __TX_frame.data.u8[7]);
      printf("==============================================================================\n");
      printf("..Frame written\n");
      vTaskDelay( 1000  / portTICK_PERIOD_MS);  // to see ( printf on receiver side ) what happend..
      counter++;
      if (counter >= 256) counter = 0;
each "Master" - i name it CAN-Controll
then decides to use the Information for a "address"
example:
this prints each Info..
if you want to use a Info of a certain address, check out the line
if ( __RX_frame.MsgID == YOUR_CHOICE) {..
example:
void task_CAN( void *pvParameters ){
    (void)pvParameters;
    //frame buffer
    CAN_frame_t __RX_frame;
    //create CAN RX Queue
    CAN_cfg.rx_queue = xQueueCreate(10,sizeof(CAN_frame_t));
    //start CAN Module
    CAN_init();
    while (1){
        //receive next CAN frame from queue
        	//do stuff!
			/* brief: rudi
			* new we switch to NODE Identifier here
			* only if we are interest to this comming node
			* we print / use the node date where commes in from
			/* @Beck: here is your magic if you want only from a certain node */
			// if ( __RX_frame.MsgID == YOUR_CHOICE) {
			// printf("New Frame form 0x%08x, DLC %d, dataL: 0x%08x, dataH: 0x%08x \r\n",__RX_frame.MsgID,  __RX_frame.DLC, __RX_frame.data.u32[0],__RX_frame.data.u32[1]);
			printf("Frame from : 0x%08x, DLC %d \n", __RX_frame.MsgID, __RX_frame.DLC);
			printf("D0: 0x%02x, ", __RX_frame.data.u8[0]);
			printf("D1: 0x%02x, ", __RX_frame.data.u8[1]);
			printf("D2: 0x%02x, ", __RX_frame.data.u8[2]);
			printf("D3: 0x%02x, ", __RX_frame.data.u8[3]);
			printf("D4: 0x%02x, ", __RX_frame.data.u8[4]);
			printf("D5: 0x%02x, ", __RX_frame.data.u8[5]);
			printf("D6: 0x%02x, ", __RX_frame.data.u8[6]);
			printf("D7: 0x%02x\n", __RX_frame.data.u8[7]);
        	//loop back frame
        	// CAN_write_frame(&__RX_frame);
			// } /* comment out if you use YOUR_CHOICE */
hope this helps
iosixllc
Postby iosixllc » Fri May 12, 2017 7:16 am
A note - unless you are only going to configure on a hard power-up (instead of after firmware OTA or other reset), you should add the following after the Pelican mode change [MODULE_CAN->CDR.B.CAN_M = 0x1;]:
MODULE_CAN->MOD.B.RM = 1;
Otherwise, the code cannot change the module configuration.
