Has anyone got one of these to work?
I have a Waveshare 2.4" LCD (ILI9341) that I'm trying to run from an ESP32 Devkit V1 (30 pins)
https://www.waveshare.com/wiki/2.4inch_LCD_Module
It's a blue-ish PCB and there is NO MISO pin.
All 3 sketches I've tried (with the pins below) give just a white screen -
Bodmer.s Fonts_demo with the TFT_eSPI.h library
Vaveshare's own example for Arduino
Adafruit's example with Adafruit_GFX.h and Adafruit_ILI9341.h
#define TFT_MOSI 23
#define TFT_SCLK 18
#define TFT_CS 15
#define TFT_DC 2
#define TFT_RST 4
#define TFT_BL 32
Any help would be gratefully appreciated.
Waveshare SPI 2.4" LCD - no MISO
Re: Waveshare SPI 2.4" LCD - no MOSI
There's no miso because the lcd doesn't send any data, it only receives data and displays.
From your link:
The code snippet of your 3 sketches doesnt have define MOSI, do you have that? MOSI / DIN is how you send data in to the lcd
PS your post title.says "no MOSI" but your text says "no MISO", a typo
From your link:
Did you read the datasheet?Note: It is not like the traditional SPI protocol, it only uses MOSI to send data from master to slave for the LCD display. For details please refer to Datasheet Page 105.
Re: Waveshare SPI 2.4" LCD - no MISO
Hi Becorey,
Thanks for the typo alert, fixed.
Waveshare's name for MOSI is DIN.
Yes, I've read the datasheet thoroughly - this is the first SPI device I've ever had.
I haven't found any examples of this type of display in actual use.
All of the pin combinations I've tried so far just give a white screen.
Apparently -
"The Adafruit graphics test outputs 5 register values at the start, these show if your SPI bus is connected correctly."
Mine show all zeroes, which is not good.
Apparently -
Did you ever get this to work? I'm stuck at the exact same place
Hi Balooski,
Unfortunately no, I never did on an ESP32.
However it did work for a day on an Arduino, then white-screened again.
It suddenly started to work OK when I was waggling its leads.
Kept going for a day while I played with the code, then stopped.
I was able to get this working. My setup:
ESP32-32 WROOM-1
Waveshare 2.4" LCD ILI9341 Controller
SCLK_PIN GPIO_NUM_12
MOSI_PIN GPIO_NUM_11
DC_PIN GPIO_NUM_2
CS_PIN GPIO_NUM_15
RST_PIN GPIO_NUM_4
Baudrate 9600 (I have set this as high as 256000 without issue)
I used the Adafruit Gfx library
ESP32-32 WROOM-1
DC_PIN GPIO_NUM_2
CS_PIN GPIO_NUM_15
RST_PIN GPIO_NUM_4
Hi Drloko,
Thanks for posting.
I think my panel is broken, although backlight control is working.
Thanks for posting.
Users browsing this forum: PerplexityBot and 3 guests
