What's the diffrence between WIFI_PROTOCOL_LR and WIFI_PROTOCOL_11N?
huang.yan
Postby huang.yan » Tue Aug 17, 2021 9:45 am
Does WIFI_PROTOCOL_LR capture more data than WIFI_PROTOCOL_11B|WIFI_PROTOCOL_11G|WIFI_PROTOCOL_11N?
Minatel
Re: What's the diffrence between WIFI_PROTOCOL_LR and WIFI_PROTOCOL_11N?
Postby Minatel » Tue Aug 17, 2021 4:42 pm
Can you make your question a little bit more specific?
For the Wi-Fi LR, please see: https://docs.espressif.com/projects/esp ... g-range-lr
Screenshot from 2021-08-17 17-41-18.png (61.14 KiB) Viewed 10423 times
huang.yan
Postby huang.yan » Wed Aug 18, 2021 4:07 am
My application scenario is that esp32 works in promiscuous mode. I hope to catch as many packets as possible.Which is the better choice, B|G|N or LR or B|G|N|LR?
esp_wifi_set_mode(WIFI_MODE_STA);
const uint8_t protocol = WIFI_PROTOCOL_11B | WIFI_PROTOCOL_11G | WIFI_PROTOCOL_11N;
// const uint8_t protocol = WIFI_PROTOCOL_LR; // long range mode
// const uint8_t protocol = WIFI_PROTOCOL_11B | WIFI_PROTOCOL_11G | WIFI_PROTOCOL_11N| WIFI_PROTOCOL_LR;
esp_wifi_set_protocol(WIFI_IF_STA, protocol);
huang.yan
Postby huang.yan » Wed Aug 18, 2021 4:08 am
Minatel
Postby Minatel » Wed Aug 18, 2021 9:10 am
I don't think you can use the Long Range for this application, since the LR mode is a proprietary mode any may not affect the reception sensitivity (for sniffer purpose).
In your application, the antenna is the only thing you should try to change in order to increase sensitivity. Antenna diversity is another option, but a little more complex to implement it.
Users browsing this forum: Amazon [Bot], Baidu [Spider], Qwantbot, Semrush [Bot] and 3 guests
