Unstable partition API flashing functions
Angus
Re: Unstable partition API flashing functions
Postby Angus » Tue Mar 28, 2017 2:29 am
It's a menuconfig option, but it was only added very recently. If you have an IDF branch with the fixes discussed in this thread then you should have it, though.
imtiaz
Postby imtiaz » Tue Mar 28, 2017 7:41 pm
Hi Angus,
the "FreeRTOS Timer Task Priority" setting is not on the ""spi_flash_lock_period branch"" - so I'll have to wait for this branch to be merged into master first to test it.
Also - it seems that having a 5msec or so delay inside the socket server thread stops the lock up issue or at least minimises it.I can live with it for now.
Angus
Postby Angus » Tue Mar 28, 2017 11:26 pm
If you get the latest master then you will have this fix. Very interested to find out if it makes a difference.
Angus
imtiaz
Postby imtiaz » Thu Apr 27, 2017 9:52 pm
Hi @ESP_Angus,
I''ve updated to the latest Master branch of the IDF (as of yesterday v2.0-rc1-666-g0fe765a9) . The function to calculate the Md5 hash using memory map of the SPI flash is now hanging and causing WDT reset.
Any ideas - Free rtos timer priority is 6 , my thread from which the function that maps the memory is called is set to 1
    1460 : 489252
    1192 : 490712
    File Size : 491904
    Guru Meditation Error: Core 0 panic'ed (Interrupt wdt timeout on CPU0)
    ets Jun 8 2016 00:22:57
    rst:0x8 (TG1WDT_SYS_RESET),boot:0x16 (SPI_FAST_FLASH_BOOT)
    rst:0x7 (TG0WDT_SYS_RESET),boot:0x16 (SPI_FAST_FLASH_BOOT)
    configsip: 0, SPIWP:0x00
    mode:DIO, clock div:2
    load:0x3fff0008,len:8
    load:0x3fff0010,len:4288
    load:0x40078000,len:10236
    load:0x40080000,len:252
    0x40080000: _iram_start at ??:?
    entry 0x40080034
    0x40080034: _iram_start at ??:?
    W (89) boot: PRO CPU has been reset by WDT.
    W (90) boot: WDT reset info: PRO CPU PC=0x400913d6
    0x400913d6: rtc_clk_slow_freq_get at C:/esp32/esp-idf/components/soc/esp32/rtc_clk.c:432
    (inlined by) rtc_clk_slow_freq_get_hz at C:/esp32/esp-idf/components/soc/esp32/rtc_clk.c:204
    W (90) boot: WDT reset info: APP CPU PC=0xd75145c6
Angus
Postby Angus » Fri Apr 28, 2017 1:51 am
Can you post the snippet of code that displays this problem? If you comment this calculation out does everything run as expected?
imtiaz
Postby imtiaz » Fri Apr 28, 2017 2:11 am
Yes - everything works if you dont call function below
static BOOL VerifyBinFileFromFlash(const esp_partition_t* p , size_t FileLen , unsigned char * FileHash)
	struct MD5Context MyMD5;
	unsigned char MyDigest[16];
	MD5Init(&MyMD5);
	spi_flash_mmap_handle_t handle;
	const void *image_data;
	esp_partition_mmap(p, 0, FileLen, SPI_FLASH_MMAP_DATA, &image_data, &handle);
	assert(image_data != NULL);
	MD5Update(&MyMD5 , image_data, FileLen);
	spi_flash_munmap(handle);
	MD5Final(MyDigest , &MyMD5);
	for(uint8_t i=0;i<16;i++)
		TRACE_D("MD5 %d = Calc : %x , Rec : %x \n",i,MyDigest[i],FileHash[i]);
	if(memcmp(MyDigest , FileHash , 16) == 0)
		TRACE_D("File Hash Match \n");
		return True;
	else
		TRACE_E("File Hash MisMatch !!!!!!!!!!!! \n");
		return False;
imtiaz
Postby imtiaz » Sun Jul 23, 2017 9:07 pm
@ESP_Angus,
The problem is resolved - the mapped partition cannot be exactly the same size as the call to the MD5 function , needs to be 4 byte bigger I am assuming..
  • Hi,
    I still have an issue with the MD5 function - it is often just hanging.
    called as follows:
    If you try a file length of 256k (262144) you may see the issue.
    If I call MD5Update in 256 byte chunks rather than the full file - it gets stuck when called with address 249856 ...
    		uint32_t Hashed = 0;
    		while(Hashed!=FileLen)
    			MD5Update(&MyMD5 , image_data+Hashed, 256);
    			Hashed+=256;
    			TRACE_D("%d\n",Hashed);
    and then I would get a WDT reset - quick resolution would be highly appreciated
    Imtiaz
WiFive
Postby WiFive » Mon Jul 24, 2017 12:22 am
You mean rounded up to the nearest 4 byte boundary?
pratik.yadav.455
Postby pratik.yadav.455 » Mon Dec 25, 2017 8:36 am
Hello @ESP_Angus @ESP_Sprite
Having problem of AP drop off.
I created HTTP server.
In my application my client send file to server, And server Store that file in to SPIFFS .
More detail is on following thread.
http://bbs.esp32.com/viewtopic.php?f=13&t=3891
Is there anything i missed?
Let me know if need any information from my side.
Users browsing this forum: Bing [Bot], ChatGPT-User, Qwantbot and 7 guests
