Hello everyone,
I have a problem with the MQTT receiver. I'm sending a message using proto file like
TurnOn/ On j
2 <reply/ 24: 0A: C4: 40: D5: 7C / 9d3cc41f-0d35-4543-8521-1bdd63c59b99 "
But in the ESP32 code I got:
And (18713) Mqtt: DATA =
Switch / selector
2
Cuts out some information like "reply ...."
MQTT problem
Re: MQTT problem
I have only code for receiving information.
But If I use for example MQTT explorer like external APP I can see corect frame.
esp_err_t Protocols::Mqtt::mqttEventHandlerCb(esp_mqtt_event_handle_t t_event)
std::string userContext = *((std::string*) t_event->user_context);
switch (t_event->event_id)
case MQTT_EVENT_CONNECTED:
break;
case MQTT_EVENT_DISCONNECTED:
ESP_LOGI(Protocols::Mqtt::TAG, "MQTT_EVENT_DISCONNECTED - client %s", userContext.c_str());
break;
case MQTT_EVENT_SUBSCRIBED:
ESP_LOGI(Protocols::Mqtt::TAG, "MQTT_EVENT_SUBSCRIBED, msg_id=%d", t_event->msg_id);
break;
case MQTT_EVENT_UNSUBSCRIBED:
ESP_LOGI(Protocols::Mqtt::TAG, "MQTT_EVENT_UNSUBSCRIBED, msg_id=%d", t_event->msg_id);
break;
case MQTT_EVENT_PUBLISHED:
ESP_LOGI(Protocols::Mqtt::TAG, "MQTT_EVENT_PUBLISHED, msg_id=%d", t_event->msg_id);
break;
case MQTT_EVENT_DATA:
ESP_LOGI(Protocols::Mqtt::TAG, "MQTT_EVENT_DATA");
ESP_LOGD(Protocols::Mqtt::TAG,"TOPIC= %.*s", t_event->topic_len, t_event->topic);
break;
case MQTT_EVENT_ERROR:
ESP_LOGI(Protocols::Mqtt::TAG, "MQTT_EVENT_ERROR - client %s", userContext.c_str());
break;
default:
break;
return ESP_OK;
}Re: MQTT problem
Not sure what that character is, but the issue may be that it's a NULL (ASCII value 0). In that case, ESP_LOG* (which is based on printf) will stop printing data there. Your data still is in the string, you may simply need to filter out that character for it to log correctly.
Users browsing this forum: PerplexityBot, Qwantbot and 5 guests
