ESP32-C3-MINI-1 programming
gfeller
Postby gfeller » Thu Sep 02, 2021 9:32 am
I got into a problem when trying to program the ESP32-C3-MINI-1 module on my electronics.
Programming software: flash_download_tool_3.8.8
When I checked with a terminal emulator on the debug port (I want to use for programming as well), I see the following:
ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
rst:0x1 (POWERON),boot:0x0 (USB_BOOT)
wait usb download
Is there a bootloader version that only supports firmware download over USB ?
I never had this problem before (always connected my modules over UART 0 for FW uploads), and the USB pins are not routed on my electronic.
Thanks for any ideas that may help!
BR, Martin
Re: ESP32-C3-MINI-1 programming
Postby Sprite » Fri Sep 03, 2021 2:22 am
I think you should make sure your bootstrap (strapping) pins are set correctly, that seems to be the issue here. Refer to the ESP32C3 datasheet for the correct pins and settings.
Users browsing this forum: Baidu [Spider], ChatGPT-User, Semrush [Bot] and 1 guest
