https request failed
axel_hpplt
Postby axel_hpplt » Tue Sep 07, 2021 1:21 am
Hello everyone,
When I run this code :
Code: Untitled.c Select all
#include <stdio.h>
#include <string.h>
#include "esp_system.h"
#include "esp_console.h"
#include "esp_vfs_dev.h"
#include "esp_vfs_fat.h"
#include "esp_wifi.h"
#include "driver/uart.h"
#include "nvs_flash.h"
#include "esp_http_client.h"
#define EXAMPLE_ESP_WIFI_SSID "iPhone"
#define EXAMPLE_ESP_WIFI_PASS "XXXXXXXXXXXX"
void app_main(void)
char dest[100] = "https://XXXXXXXXXXXXXXXXX.com/connect.php?texte=";
setvbuf(stdin, NULL, _IONBF, 0);
setvbuf(stdout, NULL, _IONBF, 0);
ESP_ERROR_CHECK(uart_driver_install(CONFIG_ESP_CONSOLE_UART_NUM, 256, 0, 0, NULL, 0));
esp_vfs_dev_uart_use_driver(CONFIG_ESP_CONSOLE_UART_NUM);
esp_vfs_dev_uart_port_set_rx_line_endings(CONFIG_ESP_CONSOLE_UART_NUM, ESP_LINE_ENDINGS_CR);
esp_vfs_dev_uart_port_set_tx_line_endings(CONFIG_ESP_CONSOLE_UART_NUM, ESP_LINE_ENDINGS_CRLF);
nvs_flash_init();
wifi_init_config_t cfg = WIFI_INIT_CONFIG_DEFAULT();
ESP_ERROR_CHECK(esp_wifi_init(&cfg));
wifi_config_t wifi_config = {
.sta = {
.ssid = EXAMPLE_ESP_WIFI_SSID,
.password = EXAMPLE_ESP_WIFI_PASS,
.threshold.authmode = WIFI_AUTH_WPA2_PSK,
.pmf_cfg = {
.capable = true,
.required = false,
ESP_ERROR_CHECK(esp_wifi_set_mode(WIFI_MODE_STA));
ESP_ERROR_CHECK(esp_wifi_set_config(WIFI_IF_STA, &wifi_config));
ESP_ERROR_CHECK(esp_wifi_start());
esp_wifi_connect();
printf("Connected...");
char chr[40];
while(1){
printf("Enter Data : ");
scanf("%39s\n", chr);
printf(strcat(dest, chr));
.url = strcat(dest, chr)
esp_http_client_handle_t client = esp_http_client_init(&config);
esp_http_client_perform(client);
I got this error :
Code: Untitled.txt Select all
assertion "Invalid mbox" failed: file "C:/Users/XXXX/Desktop/esp-idf/components/lwip/lwip/src/api/tcpip.c", line 455, function: tcpip_send_msg_wait_sem
I have no idea how to solve this problem.
Thanks you in advance.
AH.
mbratch
Re: https request failed
Postby mbratch » Tue Sep 07, 2021 10:43 am
Why are you concatenating `chr` to `dest` twice?
        printf(strcat(dest, chr));   // <-- here
            .url = strcat(dest, chr)   // <-- here
It's also not a good idea to concatenate to a literal string. Rather, you should do something like this:
const char *pref = "https://XXXXXXXXXXXXXXXXX.com/connect.php?texte=";
char dest[100];
... // code that defines chr
strcpy(dest, pref);
strcat(dest, chr);    // <-- NOTE do this only once
axel_hpplt
Postby axel_hpplt » Tue Sep 07, 2021 9:57 pm
char dest[100];
strcpy(dest, pref);
Thanks you for your reply. So, I've made your changes :
#include <stdio.h>
#include <string.h>
#define EXAMPLE_ESP_WIFI_SSID "iPhone de Axel"
#define EXAMPLE_ESP_WIFI_PASS "axelcroque2002"
void app_main(void)
const char *pref = "https://101testingesp32.000webhostapp.com/connect.php?texte=";
char dest[100];
nvs_flash_init();
.sta = {
.pmf_cfg = {
.capable = true,
.required = false,
esp_wifi_connect();
char chr[40];
while(1){
strcpy(dest, pref);
But, I get the same error. Does anyone else have a solution please ?
Postby Sprite » Wed Sep 08, 2021 2:28 am
Note that esp_wifi_connect() only *starts* a connection attempt, and will return more-or-loss immediately; the connection isn't actually created at that time. Suggest you check e.g. the examples in esp-idf to see how to properly wait until it is.
axel_hpplt
Postby axel_hpplt » Wed Sep 08, 2021 11:11 am
Thanks for your answer, I looked at what you told me (esp-idf/examples/wifi/getting-started/station) but I didn't find the way to wait properly, could you enlighten me?
fasani
Contact:
Postby fasani » Sat Sep 11, 2021 6:21 am
Hello Axel,
You need to use events, just as the example uses, in order to get it working.
epdiy collaborator | http://fasani.de Fan of Espressif MCUs and electronic design
YJM
Postby YJM » Sun Sep 26, 2021 6:20 am
Maybe you missed the esp_netif_init(), you can follow https://github.com/espressif/esp-idf/bl ... .c#L70-L73
Users browsing this forum: meta-externalagent and 5 guests
