程序的下载烧入都是可以的,
命令行openocd -f board/esp32c3-builtin.cfg
Open On-Chip Debugger v0.10.0-esp32-20210401 (2021-04-01-15:46)
Licensed under GNU GPL v2
For bug reports, read
Info : only one transport option; autoselect 'jtag'
Warn : Transport "jtag" was already selected
force hard breakpoints
Error: esp_usb_jtag: could not find or open device!
ESP32-c3-devkitm1想去gdb调试,发现识别不到设备
Re: ESP32-c3-devkitm1想去gdb调试,发现识别不到设备
开发板只需要USB线连接就行了吧?
在设备管理器中看到的是 Silicon Labs CP210x USB to UART Bridge(COM10).
不是,builtin 的 jtag 需要用到 C3 的 USB 管脚,IO18 和 IO19,需要接 USB 线,你可以买一个 USB 转杜邦线,如这样的:https://item.taobao.com/item.htm?spm=a2 ... etail。板子上的 USB 口是接到转串口的芯片上的。
是可以识别到了,然后我用openocd -f board\esp32c3-builtin.cfg开启openocd不是,builtin 的 jtag 需要用到 C3 的 USB 管脚,IO18 和 IO19,需要接 USB 线,你可以买一个 USB 转杜邦线,如这样的:https://item.taobao.com/item.htm?spm=a2 ... etail。板子上的 USB 口是接到转串口的芯片上的。
命令行openocd -f board\esp32c3-builtin.cfg
Info : esp_usb_jtag: Device found. Base speed 40000KHz, div range 1 to 255
Info : clock speed 40000 kHz
Info : JTAG tap: esp32c3.cpu tap/device found: 0x00005c25 (mfg: 0x612 (Espressif Systems), part: 0x0005, ver: 0x0)
Info : datacount=2 progbufsize=16
Info : Examined RISC-V core; found 1 harts
Info : hart 0: XLEN=32, misa=0x40101104
Info : [0] Found 8 triggers
再在另一个终端输入xtensa-esp32-elf-gdb -x gdbinit build/hello-world.elf
命令行xtensa-esp32-elf-gdb -x gdbinit build/hello-world.elf
GNU gdb (crosstool-NG esp-2020r3) 8.1.0.20180627-git
Copyright (C) 2018 Free Software Foundation, Inc.
License GPLv3+: GNU GPL version 3 or later <http://gnu.org/licenses/gpl.html>
This is free software: you are free to change and redistribute it.
There is NO WARRANTY, to the extent permitted by law. Type "show copying"
and "show warranty" for details.
This GDB was configured as "--host=x86_64-host_w64-mingw32 --target=xtensa-esp32-elf".
Type "show configuration" for configuration details.
For bug reporting instructions, please see:
<http://www.gnu.org/software/gdb/bugs/>.
Find the GDB manual and other documentation resources online at:
<http://www.gnu.org/software/gdb/documentation/>.
For help, type "help".
Type "apropos word" to search for commands related to "word"...
Reading symbols from build/hello-world.elf...done.
warning: Target-supplied registers are not supported by the current architecture
0x00000000 in ?? ()
Hardware assisted breakpoint 1 at 0x42004ea0: file ../main/hello_world_main.c, line 17.
Program received signal SIGTRAP, Trace/breakpoint trap.
0x00000000 in ?? ()
(gdb)
发现使用不了gdb。应该怎样操作呢?
Users browsing this forum: Amazon [Bot] and 4 guests
