SD card access seems broken with tasks
jsarrett
Postby jsarrett » Thu May 04, 2017 5:54 am
This is a cross post to github issue #569(https://github.com/espressif/esp-idf/issues/569), because I'm not sure which is better.
When I try and access the SD card from any task other than app_main I get weird errors and often illegal instruction crashes. attached is a very simple test case. The file FOO.TXT on the root of the SD card just has one line of text.
I am testing against esp-idf from github @f73c6f875cc564fa6c9962be71eac4dbdc56aa63 which was master as of a few days ago
-James
test_sd.zip
(11.55 KiB) Downloaded 589 times
igrr
Re: SD card access seems broken with tasks
Postby igrr » Thu May 04, 2017 7:04 am
Yes, filing a Github issue is better if you can give sufficient info to reproduce the issue (which you did). Thanks for the report.
