what ESP32 asm breakpoint instruction support if need integrate in to source code
wziy520
Postby wziy520 » Fri May 05, 2017 2:12 am
I have touch some chips support _asm_("bkpt"), but look esp32 compiler not supportted "bkpt" ,
please let me know if there have an instruction for break
Re: what ESP32 asm breakpoint instruction support if need integrate in to source code
Postby Sprite » Fri May 05, 2017 2:53 am
asm("break.n 1")
will work. Be aware that you will have to manually step over the breakpoint (=modify PC to the next instruction) if you use gdb/openocd and execute this instruction.
