File System
Fugazi
File System
Postby Fugazi » Thu May 04, 2017 7:01 pm
Hi
This is the last thing I need to get my project moved from the esp8266 where I use SPIFFS to save data.
Is there anyway to replicate this yet, or another way to save a few KB of data on the esp32 easily - I have looked into the LUA port of SPIFFs, but not a good enough coder to work it out.
Any examples ?
Thanks for your help - nearly there, just need this last thing !! :)
WiFive
Re: File System
Postby WiFive » Fri May 05, 2017 2:04 am
Fugazi
Re: File System
Postby Fugazi » Fri May 05, 2017 7:55 am
Cant believe I missed that, what a muppet , need to update esp-idf:)
Thanks !
Olof Astrand
Re: File System
Postby Olof Astrand » Fri May 05, 2017 8:36 am
However, the big question is, does the example work?
I got this result,
https://github.com/Ebiroll/qemu_esp32/b ... creenlog.0
flash: ff_wl_ioctl: cmd=3
V (680) ff_diskio_spiflash: ff_wl_ioctl: cmd=2
V (690) ff_diskio_spiflash: ff_wl_read - pdrv=0, sector=0, count=1
V (690) wl_flash: read - src_addr=0x00000000, size=0x00001000[0m
V (700) wl_flash: calcAddr - addr=0x00000000 -> result=0x00001000[0m
E (700) vfs_fat_spiflash: f_mkfs failed (14)[0m
E (710) example: Failed to mount FATFS (0xffffffff)[0m
Did not work for me
Olof Astrand
Re: File System
Postby Olof Astrand » Mon May 08, 2017 10:13 am
For the record. This has been fixed in 33b8b78.
madscientist_42
Re: File System
Postby madscientist_42 » Mon May 08, 2017 7:19 pm
Probably has been...I know one of my woes a bit back was just simply fixed. We're likely to find that grabbing an update to the IDF is going to fix many things. Only drawback to getting silicon a bit earlier than the dev framework being finished. Always gettin' zapped... :twisted:
I'm a patient sort...well, after a fashion. I want to be able to get Classic fully going on these things for my own inscrutable purposes. A pet project to fix an annoyance that the BT SIG inflicted on us with these profiles that not all support yet...
Users browsing this forum: meta-externalagent and 2 guests
