Why does gcc not make use of special OP codes
jdoubleu
Postby jdoubleu » Wed Sep 29, 2021 4:46 pm
I was wondering why gcc wouldn't use specialized OP codes from the xtensa instruction set architecture (ISA).
I'm using the ESP32-WROVER-B board, which itself uses the Xtensa LX6 microprocessor. From their Overview Handbook, I learned that the Xtensa LX processor family supports some specialized extensions to their instruction set. They include "zero-overhead" loops and min/max hardware-level implementations (compare section 2.12.1 http://loboris.eu/ESP32/Xtensa_lx%20Ove ... G8.1098890). Unfortunately, I couldn't directly find out whether the ESP32 boards include these features. Neither from the comparison table in the documentation (https://docs.espressif.com/projects/esp ... rison.html) nor from the data sheet (https://www.espressif.com/sites/default ... eet_en.pdf).
However what I found were the configurations for the binutils overlays, where the loop and minmax features are enabled (compare https://github.com/espressif/xtensa-ove ... nfig.h#L71). This is true for the ESP-IDF toolchain I downloaded, as well (check
$IDF_TOOLS_PATH/tools/xtensa-esp32-elf/esp-2021r1-8.4.0/xtensa-esp32-elf/sys-include/xtensa/config/core-isa.h
). I'm not sure what
xtensa_lx106
is, because it's disabled for that platform.
In theory these features should be available, but when I check the code generated from gcc, I don't see any of those op codes in the assembly listing. Even when I use the
-O2
flag.
I get the following assembly for a
int x = (a < b) ? a : b;
Code: minmax.txt Select all
# a and b are set before
blt a11, a2, .L49
bne a2, a11, .L48
bgeu a10, a3, .L48
Furthermore I only see "normal" loops with branches:
Code: loops.txt Select all
j .L4
.L5:
# loop body
.L4:
blt a7, a4, .L5
jdoubleu
Re: Why does gcc not make use of special OP codes
Postby jdoubleu » Mon Oct 11, 2021 4:15 pm
As it turns out, the compiler indeed uses these special OP codes and outputs them in at least -O2 mode. It just so appears that they're not being used in most of my functions, probably because the compiler found a better way?
The following C code:
Code: main.c Select all
static int my_min(int a, int b)
return a < b ? a : b;
static void my_loop(int* p)
for (int i = 0; i < 64; ++i)
p[i] += 1;
int main()
int a, b;
std::scanf("%d\n%d", &a, &b);
int x = my_min(a, b);
// please don't do this ever
my_loop(&x);
std::printf("%d", x);
compiled with
xtensa-esp32-elf-gcc -S -o main.s -c main.cpp -O3
yields:
Code: main.s Select all
l32r a10, .LC1
addi.n a12, sp, 4
addi.n a11, sp, 8
call8 scanf
l32i.n a10, sp, 4
l32i.n a9, sp, 8
mov.n a8, sp
min a9, a9, a10
s32i.n a9, sp, 0
movi.n a10, 0x40
loop a10, .L2_LEND
.L2:
l32i.n a9, a8, 0
addi.n a9, a9, 1
s32i.n a9, a8, 0
addi.n a8, a8, 4
.L2_LEND:
l32i.n a11, sp, 0
l32r a10, .LC3
movi.n a2, 0
call8 printf
retw.n
As you can see, it includes the min and loop instructions. 🎉
jdoubleu
Postby jdoubleu » Mon Oct 11, 2021 4:38 pm
Interesting. The zero-overhead loop is already very constrained in terms of application. There are only few cases where this loop can be used anyways.
Users browsing this forum: Amazon [Bot], ChatGPT-User and 1 guest
