Hi all.
anyone else is getting an SSL CERTIFICATE error while trying to install latest esp-idf with the on-line installer ?
Giampaolo
Extracting E:\esp-idf-tools-4_3_1z\.espressif\dist\openocd-esp32-win32-0.10.0-esp32-20210401.zip to E:\esp-idf-tools-4_3_1z\.espressif\tools\openocd-esp32\v0.10.0-esp32-20210401
Installing ninja@1.10.2
Downloading ninja-1.10.2-win64.zip to E:\esp-idf-tools-4_3_1z\.espressif\dist\ninja-1.10.2-win64.zip.tmp
WARNING: Download failure <urlopen error [SSL: CERTIFICATE_VERIFY_FAILED] certificate verify failed: certificate has expired (_ssl.c:1125)>
WARNING: Failed to download https://dl.espressif.com/dl/ninja-1.10.2-win64.zip to E:\esp-idf-tools-4_3_1z\.espressif\dist\ninja-1.10.2-win64.zip.tmp
ERROR: Failed to download, and retry count has expired
File "E:\esp-idf-4_3_1z\\tools\idf_tools.py", line 1675, in <module>
main(sys.argv[1:])
File "E:\esp-idf-4_3_1z\\tools\idf_tools.py", line 1671, in main
action_func(args)
File "E:\esp-idf-4_3_1z\\tools\idf_tools.py", line 1322, in action_install
tool_obj.download(tool_version)
File "E:\esp-idf-4_3_1z\\tools\idf_tools.py", line 705, in download
raise DownloadError()
__main__.DownloadError
esp-idf-tools-setup-online-2.11 certificate error
Re: esp-idf-tools-setup-online-2.11 certificate error
Yes, same thing is happening to me. Haven't found a solution yet.
Please follow https://github.com/espressif/esp-idf/issues/7672 to get notified about the resolution.
Until then you can use the offline installer as a workaround. The link is provided in the linked issue.
Maybe something similar for openocd
git clone --recursive https://github.com/espressif/openocd-esp32.git
Cloning into 'openocd-esp32'...
remote: Enumerating objects: 75431, done.
remote: Counting objects: 100% (7189/7189), done.
remote: Compressing objects: 100% (2208/2208), done.
remote: Total 75431 (delta 5652), reused 6385 (delta 4954), pack-reused 68242
Receiving objects: 100% (75431/75431), 19.17 MiB | 1.01 MiB/s, done.
Resolving deltas: 100% (61694/61694), done.
Submodule 'jimtcl' (http://repo.or.cz/r/jimtcl.git) registered for path 'jimtcl'
Submodule 'src/jtag/drivers/libjaylink' (http://repo.or.cz/r/libjaylink.git) registered for path 'src/jtag/drivers/libjaylink'
Submodule 'tools/git2cl' (http://repo.or.cz/r/git2cl.git) registered for path 'tools/git2cl'
Cloning into '/home/pi/openocd-esp32/jimtcl'...
fatal: unable to access 'http://repo.or.cz/r/jimtcl.git/': server certificate verification failed. CAfile: none CRLfile: none
fatal: clone of 'http://repo.or.cz/r/jimtcl.git' into submodule path '/home/pi/openocd-esp32/jimtcl' failed
Failed to clone 'jimtcl'. Retry scheduled
Cloning into '/home/pi/openocd-esp32/src/jtag/drivers/libjaylink'...
fatal: unable to access 'http://repo.or.cz/r/libjaylink.git/': server certificate verification failed. CAfile: none CRLfile: none
fatal: clone of 'http://repo.or.cz/r/libjaylink.git' into submodule path '/home/pi/openocd-esp32/src/jtag/drivers/libjaylink' failed
Failed to clone 'src/jtag/drivers/libjaylink'. Retry scheduled
Cloning into '/home/pi/openocd-esp32/tools/git2cl'...
fatal: unable to access 'http://repo.or.cz/r/git2cl.git/': server certificate verification failed. CAfile: none CRLfile: none
fatal: clone of 'http://repo.or.cz/r/git2cl.git' into submodule path '/home/pi/openocd-esp32/tools/git2cl' failed
Failed to clone 'tools/git2cl'. Retry scheduled
Failed to clone 'tools/git2cl' a second time, aborting
Failed to clone 'jimtcl' a second time, aborting
Failed to clone 'src/jtag/drivers/libjaylink' a second time, aborting
Users browsing this forum: Amazon [Bot], Baidu [Spider], PerplexityBot and 1 guest
