Removing node from APP doesn't remove it from the dashboard
endlessparadigm
Postby endlessparadigm » Wed Oct 27, 2021 10:56 pm
How can we delete a node from the rainmaker dashboard? I'm not able to see any options to achieve that so far.
I checked esp_rmaker_factory_reset function and that apparently wipes off the nvs data only. How can the node and user association be properly deleted?
Piyush
Re: Removing node from APP doesn't remove it from the dashboard
Postby Piyush » Thu Oct 28, 2021 11:36 am
Nodes seen in Dashboard are the claimed nodes to which you have admin access, whereas the nodes you see in phone app are the ones to which you have an end user level access. End user access can be removed, but admin access stays forever (by design). You can refer User roles document to understand more about this.
endlessparadigm
Postby endlessparadigm » Thu Oct 28, 2021 10:28 pm
Thanks for the clarification however I wanted to know if there is any way I can remove admin access to the node as well? Maybe from the dashboard?
marcarleto
Postby marcarleto » Mon Jan 30, 2023 2:50 pm
Did you manage to solve this issue? I'm having the same problem and I want to delete the node from cloud.
