How to trigger ESP32 C3 into FW download mode externally?
tommyliu0804
Postby tommyliu0804 » Sat Oct 30, 2021 3:03 am
I follow the following link:
https://docs.espressif.com/projects/esp ... the-device
For Automatic bootloader, I wonder the behavior of DTR/RTS will same as FT232(FTDI)?
I try to use the FT232 and also apply the transistor and RC delay circuit, but still can not get flash_download_tool works.
Which part should I need to check if use FT232 instead of CP2012?
The 2.12.36.4 is the version of FTDI driver I used in windows 10.
When I press boot and then RST, the console shows following:
ESP-ROM:esp32c3-api1-20210207
Build:Feb 7 2021
rst:0x1 (POWERON),boot:0x4 (DOWNLOAD(USB/UART0/1))
waiting for download
Is that means the C3 get into download mode just like the automatic bootloader do?
felmue
Re: How to trigger ESP32 C3 into FW download mode externally?
Postby felmue » Sat Oct 30, 2021 7:50 am
Hello @tommyliu0804
maybe this document helps? Check out section `Strapping Pins`.
https://www.espressif.com/sites/default ... eet_en.pdf
Felix
LJH
Postby LJH » Mon Nov 01, 2021 3:58 am
When you use flash download tool, what is the error log? sync error? If yes, you could modify RC values to match to the correct sequence.
puckbully
Postby puckbully » Tue Nov 02, 2021 5:53 pm
Hello
Where do you see this printout on the console?
How did you connect your ESP32-C3 to the computer? By UART0 interface?
I think you only see the ROM messages during the boot up. See also on the bottom of Table 4 in the datasheet.
You can disable this printout by changing the eFuse field EFUSE_UART_PRINT_CONTROL. For this check the technical reference manual
https://www.espressif.com/sites/default ... ual_en.pdf
Best regards
