how to cancel (stop) a piece of code?
HyperUniverse
Postby HyperUniverse » Sun Nov 07, 2021 7:27 pm
I've got this piece of code that is changing the colour of 10 LEDs:
void Circle_Rainbow() {
	sendData(Turn_LED3_Red, 8);
	vTaskDelay(75 / portTICK_PERIOD_MS);
	sendData(Turn_LED4_Amber, 8);
	sendData(Turn_LED5_Blue, 8);
	sendData(Turn_LED6_White, 8);
	sendData(Turn_LED7_Green, 8);
	sendData(Turn_LED8_Red, 8);
	sendData(Turn_LED9_Amber, 8);
	sendData(Turn_LED0_Blue, 8);
	sendData(Turn_LED1_White, 8);
	sendData(Turn_LED2_Green, 8);
how can I cancel it at any point, after I've started it, if I wish to?
I'll use a button to cancel it, but I can't figure out how.
Right now, if I start it, I need to wait until is finished.
Maybe I need to modify the code so I won't change the LED's colour from inside a void?
Anybody can give me a hint?
Thanks,
Regards.
Victoria Nope
Re: how to cancel (stop) a piece of code?
Postby Victoria Nope » Sun Nov 07, 2021 11:12 pm
You can use a timer from which you would send the data in turn for each LED with every tick. And such timer you'd then control from button interrupt routine.
HyperUniverse
Postby HyperUniverse » Mon Nov 08, 2021 3:38 pm
Thanks Victoria Nope, I'll need a couple of days to do that.
Regards.
Users browsing this forum: Applebot, Baidu [Spider], Qwantbot, Semrush [Bot] and 1 guest
