ESP32 PPP disconnection re-connection issue
Re: ESP32 PPP disconnection re-connection issue
That resistor is there because of EMC reasons... if during your EMC testing you find out that there's emissions from your UART1 TX pin, you could try also putting a 470 ohm resistor there, but from what I know, it's only an issue on UART0. Regardless, having or not having the resistor shouldn't affect anything else.
Thanks so much for information. I've scoped the RX/TX and I notice that there are voltage spikes while RX/TX in UART1. when I add series resistor its much more smoother.. I've came over this issue https://github.com/espressif/arduino-esp32/issues/2198.
Moreover, may I know the value of internal pullup resistor in esp?
Would like to get your opinion on above, thanks!
Users browsing this forum: Amazon [Bot], ChatGPT-User and 3 guests
