Hi everybody,
I'm testing blufi example and I would like to disable all the debug log. I have setup in "make menuconfig" the level for bootloader and component log to NONE, but I still have these debugs at start-up
ets Jun 8 2016 00:22:57
configsip: 0, SPIWP:0x00
mode:DIO, clock div:2
load:0x3fff0008,len:8
load:0x3fff0010,len:40
load:0x40078000,len:8956
ho 0 tail 12 room 4
load:0x40080000,len:252
entry 0x40080034
BTDM CONTROLLER VERSION: 010101
btip start
copy .data from 4000d890 to 3ffae6e0, len 00001830
set .bss 0x0 from 3ffb8000 to 3ffbff70, len 00007f70
BTDM ROM VERSION 0101
BD_ADDR: 24:0A:C4:00:44:A2
NVDS MAGIC FAILED
RF Init OK with coex
Enable Classic BT
Enable Low Energy
The first part (up to "entry 0x40080034") I know that it can be removed pulling GPIO15 to GND, however I can't do that on our PCB.
The second part it seems included in the library "libbtdm_app.a".
My questions are:
-How can I disable the first part of the log from software or configuration?
-How can I disable the Dual mode bluetooth debug?
disable all logs debug in blufi example
Re: disable all logs debug in blufi example
The first part (ROM bootloader log) can only be disabled using GPIO15.
Regarding the second part, will check and let you know.
Users browsing this forum: Baidu [Spider], eriksl, Qwantbot, Semrush [Bot] and 2 guests
