ESP32 Deep Sleep Wake by Multiple External GPIO Interrupt with Active Low Configuration
dovov97815
Postby dovov97815 » Mon Dec 13, 2021 5:17 am
As ESP32 have 2 wake external source :
1. external 0 interrupt (only 1 pin and level High or Low both available)
2. external 1 interrupt (Multiple pins but All Low or any High available)
I need to use Multiple Pins External Interrupt Detection with Active Low Configuration.
but In external 1 interrupt All Low or any High are only available options, not any Low.
So,
1) why ESP32 Uses this type of interrupt configuration for deep sleep wakeup. and what's the purpose for all low pins interrupt?
2) Is there a way to use Active Low Configuration for deep sleep wake?
Thank You
felmue
Re: ESP32 Deep Sleep Wake by Multiple External GPIO Interrupt with Active Low Configuration
Postby felmue » Mon Dec 13, 2021 7:21 am
Hello @dovov97815
make usage of the ULP seems to cover that use case: https://github.com/hggh/esp32-ulp-example
Felix
Users browsing this forum: Amazon [Bot] and 2 guests
